Why 2006+ HID lights ???
Old Sep 25, 2007 | 03:28 AM
Scrooge's Avatar
I search and couldn't find anything on why people would buy 2006+ for the 2003-2005 HID lights. How are there 2006 HID compared to 2003-2005 lights. Please someone tell me ????
Old Sep 25, 2007 | 03:44 AM
TIAN's Avatar
Hold The Line
Projector lights
Old Sep 26, 2007 | 01:10 AM
Scrooge's Avatar
So is that better, Sorry but I don't know that much about HID's.
Old Sep 26, 2007 | 01:26 AM
Alee786's Avatar
Hey also can we use the 2003 ballasts for the 06-07 head lights, iam thinking about switching mine out with the new ones? has anyone tried this and does it work fine. or i need to buy new ballasts as well for the new projector style headlights?
Old Sep 26, 2007 | 01:30 AM
yolkyolkyolk's Avatar
i believe you can use the old ballasts with the new headlights
Old Sep 26, 2007 | 01:31 AM
WaLLy's Avatar
yes it's better.
they'll work just fine. And I'm speaking about the coupes headlights/ballasts.
Old Sep 26, 2007 | 01:43 AM
Alee786's Avatar
yes sorry..i forgot to mention 2003 coupe...okay thanks guys..so its just direct plug n play no mods required?
Old Sep 26, 2007 | 01:44 AM
WaLLy's Avatar
I'm not much of a DIY'er and I handled the swap quite well, even when doing it at night! lol
Direct plug & play.
Old Sep 26, 2007 | 01:50 AM
TIAN's Avatar
Hold The Line
HID lamps produce a large quantity of light in a small package in comparison with incandescent and fluorescent sources. It's typically used when high levels of light are required over large areas and when energy efficiency and/or long life are desired such as headlights
Projector lights give a broader and clearer view range. Its basically a mechanical device used to beam light by focusing light through a system of lenses. They usually consists of a light source, a reflector that focuses light rays, a condensing lens, and a projection lens. This give that mid-line effect if you were to look at projectors on a stationary obeject I believe
My 2005 has HIDs, just no projectors; Hence, the reason why poeple with 2003-2005 swap em out of 06+. Newer and better... cant go wrong
Hope this helps
Old Sep 27, 2007 | 05:25 AM
g35dguy's Avatar
projector lovin' -- projectors for the win though --
Old Sep 27, 2007 | 05:46 PM
atownpdx's Avatar
is 260 bucks for a used pair of 06-07 lights in almost new condition (no scratches) a good deal?
THanks
Old Sep 27, 2007 | 05:50 PM
Alee786's Avatar
Thats a pretty good deal, iam looking for those as well where are you getting them. let me knw thanks
Old Sep 27, 2007 | 06:03 PM
Gilley's Avatar
Be advised that only the clearance strip bulb from the 03-05 headlight housings will transfer to the 06 housings. You will need new d2s , H1, and 7440 bulbs.
Old Sep 27, 2007 | 06:06 PM
atownpdx's Avatar
cool, thanks. The ones Im looking at come with all the existing bulbs. So I am assuming I'm good to go. Install and plug em in.
Anything else?
Old Sep 28, 2007 | 05:35 AM
IvoryGT's Avatar
bc you can do this...
