06 headlight question
Old Feb 7, 2008 | 02:00 PM
MixturePinoy's Avatar
here's where the problem is that i see.. the 03-05 harness has 3 wires.. one is for the blink, one for the constent, and one for the ground.. the 06-07 harness has 2 wires.. one for the blink and the other for the ground. i'm still waiting on info on this as well, i think i know who to ask..
Old Feb 7, 2008 | 02:01 PM
redlude97's Avatar
the 03 harness has 3 wires, you have to tap into the city light power source for the third wire
Old Feb 7, 2008 | 02:05 PM
will the city light still work?
Old Feb 7, 2008 | 02:07 PM
specialist's Avatar
i am giong to look tongiht night b/c i just convert to 06 lights but i had to do the drl mod
Old Feb 7, 2008 | 02:16 PM
redlude97's Avatar
Yes, just solder it or install a t-tap on the positive wire
Old Feb 7, 2008 | 02:18 PM
that's right!!!
Old Feb 7, 2008 | 02:19 PM
redlude97's Avatar
If you guys want to wait a few days, I'll do a DIY, I currently have my 06 headlights apart
Old Feb 7, 2008 | 02:20 PM
are you finally working on the damn thing????
Old Feb 7, 2008 | 02:22 PM
redlude97's Avatar
No quads yet, just fixing a rotation issue and swapping clear lenses. Also instaling a clear lense from a projector over the turn signal
Old Feb 7, 2008 | 02:35 PM
specialist's Avatar
what do you think of do this
http://www.bmwmodifications.com/angeleyes.htm y/n?
Old Feb 7, 2008 | 02:36 PM
a few people on here buy the kits.. i'm not a fan of the angel eye look on our cars
Old Feb 12, 2008 | 03:30 AM
redlude97's Avatar
Here's a little teaser
I'll do a writeup soon
Old Feb 12, 2008 | 11:07 AM
specialist's Avatar
it was very easy to do just?
you have 3 wires 1 neg wire and 2 pos wires. hook up the 1 neg and 1 pos to the place where you cut the orginal blubs also tap in the little peanut bulb pos for the other and BAM you are done or I THINK you can just tap in the side marker on the side since they are two wires if you do the mod to the sidemarker (but don't quote me) b/c my blink and stay on when driving
Old Feb 12, 2008 | 11:11 AM
This is what I got from accordfreak:
I seen that you made your blinker in the 06-07 headlights work like the one in the 03-05.. my question to you is how did you wire this up? I know you used the harness from the 03-05 light, but how did you wire that up? since the older harness has 3 wires (blink, constent, ground) and 06-07 has only 2 wires (blink & ground)? Thanks
Tito
nah I didn't wire it to have that parking light. But it's easy to wire up if you do. Just get dual filament socket from the 03-05 headlights, dual filament bulbs and wire up the 3rd wire from the dual filament socket (parking) which is the driving lights on the fogs.
If you don't like the driving lights, just cut that wire and wire it up to the dual filament 3rd wire instead of tapping it for power.. goodluck
Old Feb 12, 2008 | 11:13 AM
  #30
Hai, are you running your citylight at all? I don't see the bulb
