how to replace park light in a 06-07 headlight?
Old Dec 26, 2007 | 12:37 AM
atownpdx's Avatar
I wana replace the little bulb which I think is the parking light. It's the little one in the upper left of the fog light housing.
Can you replace that bulb w/o removing the headlight? If so, how? (Couldnt find a DIY).
Thanks,
Old Dec 26, 2007 | 12:56 AM
MIA BlazinVQ's Avatar
brb getting cut
1. Jack up the car (optional, but it makes for more room).
2. Turn wheel completely inward.
3. Remove fender lining to access the headlight.
4. Turn the lower foglight cap left to remove it.
5. You will see a black and a yellow cable leading to the bulb. If you move it around you can see the bulb moving around from the front.
6. Use those two little cables to lead your hand to the bulb and just pinch on the clip and pull. Then just swap out the bulb and your done.
Old Dec 26, 2007 | 01:02 AM
atownpdx's Avatar
thanks!
Old Dec 26, 2007 | 03:54 AM
DrewTheSuit's Avatar
i yanked the city lights and added halos instead...just another option out there, you either love it or hate it though
Sepsis
Feb 12, 2020 02:05 PM
bTanz
Oct 15, 2015 02:31 PM
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
attarday
Jul 15, 2015 04:03 PM
