I think I'm going to upgrade both ballasts and bulbs.
Old Jan 9, 2008 | 01:21 AM
Joaquin03's Avatar
Staff ALUMNI
5000 ballasts!! that's a big *ss group buy!!!
Old Jan 9, 2008 | 09:47 AM
waijai's Avatar
i.love.gold
I still have my original 03 headlights. I'll be going with either 5000K or 6000K bulbs. If I do upgrade to 06 headlights, the new HID setup should still work on them.
Old Jan 9, 2008 | 02:07 PM
redlude97's Avatar
Now that I looked more closely at it, using those in a reflector housing would be a horrible idea, the bulbs don't have the ceramic glare shield so it will blind everyone else on the road. I don't recommend those at all. Also, d2r and d2s bulbs are not interchangeable so you can't use them on projector headlights unless you do some modification to the bulbs which will likely void your warranty
Old Jan 10, 2008 | 12:44 AM
meatbag's Avatar
They are completely interchangeable. The only difference is the glare shield thats present on the D2R and not the D2S. The base and everything else about them are exactly the same. You can use either bulb in either style of headlight but a D2S bulb in the old style housing will blind everyone and a D2R in the new housing will have diminished light output.
Old Jan 10, 2008 | 12:46 AM
meatbag's Avatar
If everyone got 4 ballast for lows and fog/hi then you only need 1250 people
Thats still only $60 for 4 ballast though lol.
Old Jan 10, 2008 | 01:04 AM
redlude97's Avatar
The problem is almost no aftermarket d2r bulbs have the glare shield, and unless the bulbs are notched for both d2r and d2s, then they are not interchangeable. OEM d2r bulbs cannot be used in d2s without modification
Old Jan 14, 2008 | 08:46 PM
texasg's Avatar
d2r is for reflective oem hid housing
d2s is for projectors
right?
Old Jan 14, 2008 | 09:06 PM
redlude97's Avatar
right?
That is correct
Old Jan 14, 2008 | 09:54 PM
pjames's Avatar
i've been thinking about converting the fogs /highbeams to hid, but i'm thinking that it might be difficult to run the drl, i assume that running half power to the ballasts won't halve the output of the bulbs (much like a fluorescent tube), any options there?
Old Jan 14, 2008 | 11:28 PM
redlude97's Avatar
Very bad idea. Any plug and play HID kit not meant for HID reflectors such as our foglights/highbeams will cause significant glare for other drivers on the road and would be a safety hazard. IMO it is completely inconsiderate to install such a kit. If you are really concerned about increased lighting, then you should look into a projector retrofit which will provide more output with a significantly improved beam pattern
Old Jan 17, 2008 | 12:59 PM
pjames's Avatar
well, good to know, didn't think it would be as much of a problem since the fogs are aimed so low, i know what you're talking about though, i see it every day.
say i did find a kit meant for reflectors such as the fog/HID, or did a projector retrofit, can they still serve as DRLs?
thanks for the info so far.
Old Jan 17, 2008 | 01:08 PM
waijai's Avatar
i.love.gold
My buddy just got his 55w kit installed and it's WAY brighter than the 35w kit he previously had. I have ordered a D2R kit for my car.
Old Jan 17, 2008 | 01:51 PM
redlude97's Avatar
Did you find out if the 55w d2r bulbs have the ceramic shielding on the glass? From the pics it doesn't
Old Jan 17, 2008 | 11:40 PM
waijai's Avatar
i.love.gold
yeah he's ordering D2R bulbs for me
Old Jan 18, 2008 | 01:59 AM
  #30
redlude97's Avatar
I don't think you understand my question, alot of aftermarket companies sell "d2r" bulbs which aren't really d2r bulbs, they don't have the ceramic shielding on the glass, they are basically d2s bulbs with a different slot cut in them to fit into d2r headlights
