O6' retrofit help???...
Old Jan 9, 2008 | 02:50 PM
mEsOaZn's Avatar
6MT VQHR Sedan
Lightbulb O6' retrofit help???...
Ok fellow G owners, i have an o5' coupe and i recently upgraded to the o6'-o7' projectors... Long story short i used the the o5's bulbs [for it to fit i had to dremel an extra groove...], which are d2r's instead of d2s's like it recommends on the headlight assembly... So everything is installed fine but the cutoff is barely visible when driving on the streets and not all that bright compared to tsx tl's and the 04+ s2000 projectors. And i admit the 04' S200s projectors are one of the best ive seen so far because a friend of mines has one. I had expect mines to be exactly if not somewhat close to that of the
s2000's. But anyways it is only really visible when i drive towards a garage or like streets that are compact or filled with obstacles... Do ya get what im saying? If anyone knows if the bulbs [d2r/d2s] make the difference, please let me know? Thanks in advance for the responses...
Old Jan 9, 2008 | 03:02 PM
sfgr415's Avatar
Its not the bulbs, its the lesnes. 06+ G35 projectors use frensel lenses which greatly decrease a sharp cutoff and color similar to that of a tsx/s2000/TL, etc.
Frensel lenses have benefits that they are not as blinding to on-coming traffic. However, you loose the sharpness/color.
If you want your car to look similar to an s2000/TL, you would have to change your lenses. TSX is a common retrofit.
Old Jan 9, 2008 | 03:04 PM
superdds's Avatar
Old Jan 9, 2008 | 03:06 PM
sfgr415's Avatar
haha... these are actually my lights...
Old Jan 9, 2008 | 03:42 PM
mEsOaZn's Avatar
6MT VQHR Sedan
Lightbulb
owwwhhh gawt daym - yea thats what im looking for wen i had swapped to the o6' projectors... now how did ya get it to look like that playboi? muahah Any help would be appreciative to a fellow "G" Thanks in advance...
Old Jan 9, 2008 | 03:57 PM
superdds's Avatar
^^^click on the link i posted above.
Old Jan 9, 2008 | 04:00 PM
mEsOaZn's Avatar
6MT VQHR Sedan
Ohww my fault didn't see ur post - so short n small... thanks bro.
Old Jan 9, 2008 | 05:17 PM
sfgr415's Avatar
Go get yourself a set of clear lense (non-frensel) TSX lenses on ebay. I think they were clear lenses up until 2005. They usually run around $150 or so.
Then, you have to find someone to do the swap for you. You can try IvoryGT.
Old Jan 10, 2008 | 01:45 AM
Hunt4m3x's Avatar
Will the 06 sedan headlights fit an 05 sedan?
Old Jan 10, 2008 | 02:29 AM
03Sg35's Avatar
They are talking about coupes, and yes the 05 do fit 06 sedans b/c its the same headlight.
NyCrAzY
Oct 1, 2015 09:19 AM
toadfire
Sep 21, 2015 07:15 AM
ENTRAPM3NT
Sep 16, 2015 01:21 AM
