OEM Fog lights info ???
Old Jan 10, 2008 | 08:13 AM
07BlackG35Stud's Avatar
Hello all,
I read on the manual that the stock fog bulbs are rated at 55W. Now, is this what they draw? Or does this number symbolize the light output? The reason I ask is that I recently purchased a set of yellow Luminics rated at 55W but the output is 130W. I know many peeps are running these fogs, but I don't know if such a high output wattage could cause issues - I noticed my light housing gets warm around the fog light area with the new bulb, however, I never bothered to check with the stockers so I don't know if it's normal. I know that if the draw wattage is higher than stock, then it could cause the harness to burn, however, these draw 55W just like stock.
Any input would greatly help. I tried searching the forums but nothing answered my question.
Thank you,
Etien
Old Jan 10, 2008 | 09:33 AM
GR8TG35's Avatar
In your case the draw is 55W and it give the equivilent of 130W output.....
You should be fine with that setup. I wouldn't go any higher on the first number.....or you could run into harness problems caused by the higher draw.
Old Jan 10, 2008 | 09:41 AM
Sportcoupe35's Avatar
Yep 55W is the draw. Alot of aftermarket headlights will show 55W and then a number over 100W that's just the amount of light output they are saying.
Old Jan 10, 2008 | 09:50 AM
Thanks guys, that's what I thought. Anyone knows what the output wattage of the OEM bulbs is? The output of the Luminics is 130W and I just wanna make sure they don't melt anything if I'm going much higher than stock. Thanks again!
Also, does the stock OEM fog light make the light housing a little hot? I never bothered to check, and now that I have the Luminics and I checked and it does get warm/somewhat hot.
Etien
Old Jan 11, 2008 | 02:27 PM
So you don't think 130W of output is too high? I touched the outside of my headlight assembly after driving with the fogs on for 20 min and it was relatively hot. I never really bothered to check while I had the stock fogs, so I'm not sure if it's normal or not. I'm trying to find out what the output for the stock H1's is.
Old Jan 11, 2008 | 06:25 PM
redlude97's Avatar
The "output" they claim is BS. It is nowhere near 130w, its just marketing but its impossible for them to put out that much light, I would even go as far as to say they put out less light than stock becuase of the colored filter
Jusseth
Sep 13, 2020 12:25 PM
Freddy07g35
Sep 17, 2015 08:53 PM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
attarday
Jul 15, 2015 04:03 PM
