Anyone other sedans hate their incandescent turn signal bulbs?
Old Feb 14, 2008 | 10:55 PM
  #31
5150DS's Avatar
Quick questions Tim. Why did you decide to go with red led's, wouldn't white be brighter not having to go through the extra layer of color (sorry for lack of technical terms)? Just wondering if you just felt like trying red or thought white would be too bright. Thanks.
Old Feb 15, 2008 | 12:51 AM
  #32
JDM_Cain's Avatar
thanks for sharing
Old Feb 15, 2008 | 01:12 AM
  #33
FlSHRFun's Avatar
Great job. I want to do this to my sedan, too.
Old Feb 15, 2008 | 04:13 AM
  #34
GixxerSteve's Avatar
(I'll jump in here Timmah)
Big negative there 5150. If we take a trip back to 5th grade science class, you'll remember that light is actually comprised of all colors of the visible spectrum. When light passes through a translucent object (such as the red plastic lens of the tail lamps), all portions of the light except for the color of the translucent object are filtered out. Simply put, a red lens filters out all but the red portion of the light. So if the light behind the lens is an all red LED, little to none of the light will be blocked by the lens. Conversely, the light from a white LED contains very little light in the red portion of the visible spectrum, so most of the light would be filtered out by a red lens.
So by using a red LED with the red lens, a high percentage of the light passes through, which makes it brighter than a white LED.
(<< climbs down off soapbox)
Old Feb 15, 2008 | 10:16 AM
  #35
mackinnr's Avatar
nice work Tim!
Old Feb 15, 2008 | 12:09 PM
  #36
Noremac's Avatar
Originally Posted by RocketG35
What is the load on the resistor? I have the right LEDs, but I never installed them because I never got around to getting resistors. I radio shack has a ton - not sure which ones I need to get.
Radio Shack [motto: "You've Got Questions? We've Got More Questions."] may or may not have high power load resistors of the size needed. Figure on needing at least a 30W resistor to simulate the missing incandescent turn-signal bulb. You probably can't go wrong with the 50W type sold by the same place selling these 3W LEDs.
Old Feb 15, 2008 | 12:10 PM
  #37
Noremac's Avatar
Ouch Just looked at the price of these 3W LEDs. $25 each
Old Feb 15, 2008 | 01:25 PM
  #38
5150DS's Avatar
Okay, so the red LED is producing red light and not being filtered through a red painted bulb.
Old Feb 15, 2008 | 02:12 PM
  #39
Swivel's Avatar
Moderator
One more from the Timmah-pedia of mods. I like this one.
Old Feb 15, 2008 | 02:39 PM
  #40
ttrank's Avatar
Grocery getter
Yes the LED is red. There are no filters or anything.
Old Feb 15, 2008 | 02:40 PM
  #41
ttrank's Avatar
Grocery getter
I would just spend the money and get the resistors from them too. You can get the ceramic ones that will do the same job but why not just get the nice ones with the heatsink and everything all delivered with the same order?
Old Feb 15, 2008 | 02:43 PM
  #42
ttrank's Avatar
Grocery getter
Me too!
Yeah to get LED's with enough output you are going to have to spend some cash. These are the best style on the market right now. If you wait a little while the price will come down. You also may be able to find this same type for less if you shop around. I have had very good luck with them so it's worth the money for peace of mind.
Originally Posted by mackinnr
nice work Tim!
Thanks!
Old Feb 15, 2008 | 02:46 PM
  #43
ttrank's Avatar
Grocery getter
Originally Posted by OCG35
not to thread jack, but anyone interested in Tim's idea might also like to consider this:https://g35driver.com/forums/g35-sedan-v35-2003-06/203027-taillight-mod-works.html
Sorry Tim, I hope you don't mind me linking form here
No prob at all Mike!
What you are working on is even better IMO. I think if Kevin can pull it off he will sell quite a few of those. Figure this cost ~$60 to do and the approx price of the module will be $100. It's well worth it.
Old Feb 20, 2008 | 12:40 PM
  #44
itgogitrev's Avatar
I hope this is up when I get home. When will it be moved?
Old Feb 20, 2008 | 12:51 PM
  #45
ttrank's Avatar
Grocery getter
I'm going to move it in the next couple days but there will be a "moved" link still there.
It will live in the lighting section so you can always find it over there.
