need help with door light
Old Feb 28, 2008 | 09:16 PM
05350GT6MT's Avatar
does anyone here know how to get to that damn light on the door?
the step courtesy light or whatever?..
cant seem to get that damn thing on
i want to switch the bulb to led
but cant seem to open it u
help please
thank you
Old Feb 28, 2008 | 09:38 PM
O HELLA OEM's Avatar
yea that shiet was a PITA!!! to take off..but i took it off with a very small and thin flat head screw driver...like get the driver and just put it on the side and pull out!..some force will be neseccary...and it should come out!..its a pain to get the new bulbs in as well..haha GL
Old Feb 28, 2008 | 10:00 PM
TheDude's Avatar
im curious as to what kind of bulb that takes because I have a bunch of them and they don't fit.
Old Feb 28, 2008 | 10:24 PM
Red_G35's Avatar
31mm festoon bulb, just changed mine. piece of cake... flathead FTW!
Old Feb 29, 2008 | 01:01 AM
05350GT6MT's Avatar
where do i put the flathead on and pull?
Old Feb 29, 2008 | 01:17 AM
Red_G35's Avatar
on either end of the light fixture, just pop it out (pops out straight down). use a lil force too
.____________
|____________|
Old Feb 29, 2008 | 01:46 AM
05350GT6MT's Avatar
ok i'll try it thank you
Old Feb 29, 2008 | 02:01 AM
BlueDevilBAMF's Avatar
Mine were a PITA to do because I had just gotten my G and didn't want to break anything - didn't have enough slack on the wire to install the new bulb and was probably too cautious. The directions others have given you are all you'll need!
Old Feb 29, 2008 | 08:21 AM
lexusk8's Avatar
Be careful when pulling the old factory bulbs out. They're extremely hot to the touch!
Old Feb 29, 2008 | 09:25 AM
2K6G35's Avatar
It's the same bulb as the dome light
Get this if you want a white LED
Get this if you want a blue LED
Old Feb 29, 2008 | 10:02 AM
mt7rabbit's Avatar
.____________
|____________|
its really not that hard just place a soft cloth on the end of the screw driver so that you don't damage the surrounding door panel. I placed the screwdriver here and it came out with no problems.
(this side towards street)
..........V
_____________
|____________|
(this side towards car interior)
Old Feb 29, 2008 | 06:36 PM
phatice's Avatar
how the hell do you guys change it, even after i popped it out the wire is so short i can't even reach the bulb, do you guys lie on the floor to do this?
Old Feb 29, 2008 | 07:23 PM
2K6G35's Avatar
I pulled the cover out slowly and turned it until I could see the bulb.
Use a glove when you pull out the buld. It's freaking HOT!!
Old Mar 3, 2008 | 03:11 PM
mt7rabbit's Avatar
yep! the cord on it is insanely short, but if you are careful it can be done.
Old Mar 11, 2008 | 01:53 AM
J. Dub's Avatar
Please follow the advise of putting a thin cloth or better yet some electrical tape around the tip of the flat head or you will end up with a scratch/dented part of the lense as I did on my dome light in my acura RSX
mike730
Jan 12, 2018 04:25 PM
RA081024
Aug 18, 2015 07:03 AM
avalino
Aug 6, 2015 01:42 PM
