Will these LED's work?
Old Mar 26, 2008 | 07:02 AM
hkhair's Avatar
hey guys,
I have an 06 G35 coupe and i got the clear front sidemarkers. I wana change the stock bulb. will this LED bulb work? and do i just switch the new bulb with the stock bulb? do i need to get anything else?
WLED-WHP Pure White High Power
12 VDC Wedge Base bulb (194/168 type)
With High Power Pure White LED
http://www.superbrightleds.com/mini-wedge.html
Old Mar 26, 2008 | 06:36 PM
Curt G's Avatar
Originally Posted by hkhair
hey guys,
Yes.
Search:
https://g35driver.com/forums/showthr...highlight=WLED
Old Mar 27, 2008 | 03:25 AM
hkhair's Avatar
thanks
Old Apr 2, 2008 | 11:03 AM
spooze's Avatar
does anyone know which color matches the stock hid headlights
Old Apr 2, 2008 | 11:14 AM
JOKER's Avatar
CLUB MODERATOR
it will work
it's very bright and matches 6k hid very well
the only negative side with it is that it is a Top mounted led
So you don't get enough light reflecting from a reflectors in your side markers.
So when up close the only thing you see eliminated is the actual led and not the entire side marker.
From further away it looks better.
I'm rocking them and it's not that bad.
Old Apr 2, 2008 | 11:23 AM
JOKER's Avatar
CLUB MODERATOR
it is not that blue in real life
Much more whiter.
Old Apr 3, 2008 | 02:08 AM
hkhair's Avatar
Thanks appreciate the help
Old Apr 3, 2008 | 02:39 AM
Red_G35's Avatar
Great bulb from superbrightleds.com, out lasted all my SMT's (5LED AND 9LED) from v-leds. Nearly as bright also, oddly enough.
I had the single LED high power in the clearance strip and vleds SMT 5LED on the sidemarker to fill it up. vled's SMT seem to die on me.. all of them.
Old Apr 4, 2008 | 11:10 PM
Curt G's Avatar
Originally Posted by JOKER
it will work
+1 Exactly my results.
Before these I was running some inverted cone LEDs in the side markers and they were too blue and still didn't throw much light off the side of the LED.
I've had these ones for years now and they're still working great. They also look great on the rear license plate (you need two there).
Old May 26, 2009 | 03:59 AM
Morcos24's Avatar
Hey Joker, What exact bulbs did you use for your clearance strip and side markers? I want to get LED sidemarkers and clearance strip LED and I like that way yours look. Let me know specs on them. Thanks
arora_g35
Apr 16, 2026 02:52 PM
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
julian.dion
Jul 29, 2015 09:16 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
attarday
Jul 15, 2015 04:03 PM
