Spoiler LED lights
Old Apr 14, 2009 | 07:12 PM
SmoothieG35's Avatar
I have the same issue with my 03 coupe, the whole strip of led lights have gone out. Could this be a fuse or something disconnected? Anyone have a diagram on how to remove it and check?
My other option is to replace the strip of leds, does anyone know which one is for me?
http://www.spoilerlights.com/servlet...G35/Categories
Thanks!!
Old Apr 15, 2009 | 02:00 PM
10nara's Avatar
On the circuit board that holds the LEDs, there are 1 resistor per a number of lights. like 4 lights to 1 resistor if I remember correctly. If a resistor goes out, then the 4 lights connected to them goes out. I went to radio shack, bought bulbs and replaced them and found out the hard way, then I lost the wire inside the spoiler that connects to lights and now I have no spoiler light. Hope it dosen't happen to others.
Old May 21, 2009 | 06:53 PM
tiguy99's Avatar
How long are those wires? Worst case, you can take the spoiler off the car and rewire it yourself. If you're good with the soldering iron, you can buy the OEM resisters and replace them yourself.
Then just add some wire to the original ones to make them longer and solder it all together and use some sort of heat shrinking wire loom to cover it all up....
Maybe a 1 hr job at best
zoop425
Mar 29, 2016 05:51 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
linedr89
Aug 17, 2015 05:11 PM
nervseele
Aug 16, 2015 03:30 PM
nickmcc123
Jul 29, 2015 05:14 PM
