sedan to coupe headlight conversion.
Old Jun 4, 2008 | 12:43 AM
freedumb's Avatar
done before?
Old Jun 4, 2008 | 12:46 AM
Phranknstein's Avatar
someone did.but not worth it imo $$$$$$$$.
Old Jun 4, 2008 | 12:47 AM
G35Papa's Avatar
So modified hood, fenders, bumper and grill.
No, I don't think its been done before.
Go for it!
G35Papa's Avatar
Post a link please
Old Jun 4, 2008 | 12:59 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
correction, someone started and has yet to finish.
it was member 'QUADCAM'
-GP-
Old Jun 4, 2008 | 01:10 AM
I knew something happend but I guess it wasn't finished my bad.....Thanx Gdup35sedan
Old Jun 4, 2008 | 01:22 AM
HwyDrftr's Avatar
Probably be easiest to replace the whole front clip,mostly just need to fit the fenders to the doors that way. I was thinking the same thing once when my friend was over with his coupe, he wouldn't go for the swap though, wouldn't swap seats either... bastid...
Old Jun 4, 2008 | 09:22 AM
NathanJax's Avatar
..... I WIN .....
If you search, it's been asked 100 times... the coupe is wider, slopes more, etc.
This guy is in the process of doing it... kinda...
https://g35driver.com/forums/showthr...upe+headlights
Old Jun 4, 2008 | 01:10 PM
keen1801's Avatar
Along the same lines, has anyone done a 05-06 front end conversion on an 03-04? I'm wondering if the mounting for the fenders, hood, headlights, front bumper would be the same. Used parts don't seem to be that expensive and the look of the 05-06 looks cleaner to me.
Old Jun 4, 2008 | 01:18 PM
G SEDAN's Avatar
In order to get the 05-06 front bumper, you have to replace fenders, headlights, and hood.
just get this on your 03-04, it looks better anyway
Old Jun 4, 2008 | 01:42 PM
Klubbheads's Avatar
Originally Posted by freedumb
done before?
y ?
Old Jun 4, 2008 | 05:03 PM
keen1801's Avatar
I've already got that bumper and it's waiting to be painted. I'd just like to know if it can be done without major modifications. People will probably ask why and say to upgrade to an 05-06 instead but I just want to know if it is possible to just unbolt the old and bolt on the new.
Old Jun 4, 2008 | 07:40 PM
OCG35's Avatar
The post below was found in this beneficial section:
https://g35driver.com/forums/g35-sedan-v35-2003-06/196616-look-here-before-starting-new-thread-2003-2006-sedan-faq-s.html
Originally Posted by ttrank
Q - Will coupe body parts fit on my sedan?
No, this includes the headlights, grille, etc! Nothing is the same.
(As a side note, there is a member trying to see how much modification will be required but as-of now, nothing fits)
Q - Can I debadge the emblems on the rear of my 1st gen sedan?
Yes - except for the mount fuji emblem which has rivets (holes). The other "INFINITI" and "G35" lettering is attached by double sided tape and can be easily removed. The most common way is to heat them with a heat gun and remove with dental floss. Then use goo gone or similar to remove the extra tape. Finish with a good wash, polish and wax.
Q - Can I get rid of the orange marker lights on my bumper?
Yes, the JDM V35 Skyline has clear ones and you can get them from any dealer but some of our sponsors keep them in stock. Grubbs Infiniti, EverythingG35.com and Tony or Jason at Riverside Infiniti.
*Stay away from the ebay ones. They are not much cheaper and not as high quality.
Q - Are there aftermarket headlights for my sedan?
Maybe...
The only options out there for plug-and-play headlights are ebay and clear corners. The ebay ones are low quality 3rd party lights which are black inside. They are only for the non-HID 03/04 sedans. Clear corners makes a LED-halo retrofit and can paint them to your color choice. They are very high quality (with a price to match).
The best option for a decent price is to open up your lights and modify them yourself. Some members have done single and bi-xenon projector retrofits, painted the bezels and installed CCFL halos.
Q - Can I swap my taillights from the 03/04 grid style to the 05/06 circle style?
Yes, they are a direct plug and play swap.
Q - Are there any LED mirror options for my sedan?
Yes but read carefully. Some only fit the JDM models and not the USDM models. Where it says "older style" they mean 03/04 and "newer" is 05/06.
http://japanparts.com/db/partslist.p...maker=&volkey=
Q - Is there a carbon fiber hood for my sedan?
First let me ask why do you want one? The oem sedan hood is aluminum and very light. A CF hood will not help much there and they never fit as well as the oem. Plus it is always a good idea to have hood pins on your CF hood because many are not made for full-time use and the resin on the latch area dries up and gives out.
Stillen makes a full CF hood for the 03/04 sedan to fit their top-mounted supercharger. From time to time you will see one listed on ebay but most of the time they say it will fit 03-06 sedan. Be cautious with these since the 03/04 sedans hood is not the same as the 05/06!
Q - Can I paint my dark gray side sills on my 03/04 sedan?
The best option is to replace them with the Nismo (Aero) sides. But, they can be painted. Some paint shops will say no and others say yes. With the proper prep and right paint/flex agent/clear they can be painted to match. Many members have done it.
Q - Can the door moldings be removed?
Yes, but be aware that there are two holes per door under the moldings. The moldings themselves are held on with double sided tape and "pins" that go inside the holes in the door to keep them straight / in place.
Q - What body kit options are there for my sedan?
First off, you need to know that the 03/04 sedan is not the same as the 05/06 sedan. The hood, headlights, grille, fenders and front bumper is different and not interchangeable between the two unless you change everything I just listed!
The side skirts and rears will swap but the 05/06 does have the trunk pop in the rear bumper.
That being said here are the options I know of and for what years:
03/04 Sedan
Factory Nissan Aero (AKA Nismo, comes painted from dealer) - urethane
Sportec (from Japan, not available in US without being imported) - fiberglass
Ebay Greddy style (does not fit well and will require lots of modification) -fiberglass
Wald lip (not full bumper, just lower lip) - fiberglass
Coupe Impul Style - (from board sponsor Klumzyee's shop, still in final stages of development) - fiberglass
Kuruma Z Style (being made by a non-sponsor shop in CA, still in development) - fiberglass
Sedan Impul (from Japan) - fiberglass
Gialla (from Japan) - fiberglass
Stillen (front lip, side skirts and rear valance) - urethane
05/06 Sedan
Oem factory lip (comes painted from dealer) - urethane
Front lip (from sponsor Klumzyee, unpainted) - urethane
Kuruma Z Style (being made by a non-sponsor shop in CA) - fiberglass
Old Jun 4, 2008 | 07:43 PM
OCG35's Avatar
if the question is: "has _ _ _ _ been done before?"...chances are the answer is in the "look here first" thread.
Unless you question is "has anyone painted over rear blinkers and made leds blink"
Old Jun 4, 2008 | 07:49 PM
G SEDAN's Avatar
who the hell would be crazy enough to wonder that?
