interior light dead help
Old Aug 22, 2008 | 04:14 AM
user 6290820's Avatar
When removing the interior light/ sunroof switch i believe they were possibly installed reversed however now corrected and the interior light will not come on automatically .
Cant find a bad fuse so i suspect there is a control module that has been damaged, anyone have an idea where that is located ?
Note, they turn on with the manual switch and the door lights turn on when i disarm, just not the map lights - however they will light when i manually turn on just not autmatically anymore.
I did remove postive for a few minutes but that did not help, I believe its the control module as the power to the key ring still lights and turns off automatically when the key is inserted - next thing to do would be to tap that light back to the interior light as a half *** fix but rather fix the control module --anyone?>
cheers
Old Jun 29, 2013 | 11:03 PM
Hai_Rolla's Avatar
Did you ever get this fixed? I have the same problem!
Old Jun 30, 2013 | 08:33 AM
Blue Dream's Avatar
I drove ttrank's car solo
Last Activity: 09-04-2008 06:01 PM
I doubt he's going to respond but thanks for searching.
Old Jul 2, 2013 | 01:52 PM
Nope, never did, problem exists. Were you doing anything that caused the issue or did they just stop? I suspect somewhere is a control box, however not sure which it is.
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
mjfenix
Aug 17, 2017 05:49 AM
derres
Aug 28, 2015 03:27 PM
Jadenkid22
Jul 14, 2015 12:33 AM
