ahh Help me...!! maplights out!
Old Aug 27, 2008 | 04:20 PM
Ching1206's Avatar
ok i was putting LEDs in my car...
those led strips..im trying to put them under the back seats...
the ground wired and the maplight wire Accidently touched...lil sparks came on..
Now my map lights are out...
Wht i do now???
HELP!!!
Old Aug 27, 2008 | 04:22 PM
julioi23's Avatar
try a new fuse or bulb
Old Aug 27, 2008 | 04:24 PM
Ching1206's Avatar
all my leds went off.....
maplight wont like....the TOP under glove compartment light off too n underdoor light...
Where are the Fuse?
Old Aug 27, 2008 | 04:48 PM
Ching1206's Avatar
shiiiiiiiiiiiiiiiiiiiiiiiiT
even the seat dont move..
Old Aug 27, 2008 | 04:56 PM
BloodlineG's Avatar
You blew an accessory fuse. Just replace it check your fuses to see which one is blown
Old Aug 27, 2008 | 04:58 PM
Ching1206's Avatar
so my lights should be Fine right?????
just need to replace them then my lgihts will come back on?
Old Aug 27, 2008 | 05:19 PM
Ching1206's Avatar
which fuse i should replace?i dont see brown fuse
is it the one with 3 fuse inside???
Old Aug 27, 2008 | 05:28 PM
Ching1206's Avatar
bump?
Old Aug 27, 2008 | 05:39 PM
Ching1206's Avatar
wait which fuse box should i look??
the one beside the door???
or the one under the hood beside battery????
Old Aug 27, 2008 | 05:58 PM
LjN_728's Avatar
^ Dude...chill and calm down. Since it doesn't hurt to look, take a look at the one by the door first. It'll have a list of what fuse controls what. Get familiarized with both fuse panels.
Old Aug 27, 2008 | 06:09 PM
Ching1206's Avatar
ok i've checked both my fuse box..
they all look fine....
well
when i put a 10a fuse into the elec slot...
i see sparks.....
but my lightts still dont react...
HELP ><"
Old Aug 27, 2008 | 06:42 PM
Ching1206's Avatar
OK..HEre the situation...
i've checked all fuse.....
they are ok...No brown...
unplug both + - battery n reconnect them...
STill no luck.....
i really need some help ><"
Old Aug 27, 2008 | 08:38 PM
jinubob81's Avatar
Evil Bastard
that's a big oops.
i thought there were fuses in the little plastic door around the driver side kick panel, as well as in the engine bay.
get a fuse tester and see which are out, and replace with the correct fuse. it definitely sounds like you just need to go over the fuses again, but with more caution.
chinee
Jun 10, 2024 07:48 PM
GXXXV
May 5, 2004 09:46 PM
dyenboy
Apr 13, 2004 02:38 PM
2slo2bfurious
Nov 25, 2003 03:04 PM
ozracer01
Sep 13, 2003 04:01 AM
