LED 'em up! 56k = PC hang
Old Mar 18, 2009 | 11:37 PM
  #196
Beebo's Avatar
Looks good Jazz4sho now time for the clearence strip
Old Mar 18, 2009 | 11:38 PM
  #197
Beebo's Avatar
Originally Posted by Wannabe6MT
Question, how the hell do i change the bulb in the glove box?
Why waste money on that? lol
Old Mar 18, 2009 | 11:43 PM
  #198
Jazz4sho's Avatar
Hey i got the UPS delivery sched for tomorrow bring clearance, and demon eyes. i got the 18 smt turn signals also. just got to make sure that the clear blinker lens come at with them. if not it will be off to home depot. sucks i got family coming in so i may not get to set it all up until sat or sun.
Old Mar 19, 2009 | 12:07 AM
  #199
FlSHRFun's Avatar
Hey, check this out. Watch the video. When they take off the glove compartment at 3:17 he disconnects a lil' wire, that's the small 74 bulb that should be replaced.
http://www.infinitihelp.com/diy/gsed...dure_video.htm
The bulb can be purchased here:
http://v-leds.com/24-74-LED/White-LE...orLanding/true
If you want to replaced the bulb on the upper glove box, you should reach behind it after removing the glove box and feel for a wire around where the bulb should be. If you look at the bulb in the upper glove box, you'll get an idea of where to feel around in the back for the wire. When you find it, it's locked in much like the bulbs in our clear corners. Simply twist and pull it out. The bulb is a 194/168/158 bulb and can be purchased here:
http://v-leds.com/194-168-158-LED/Wh...orLanding/true
Have fun!
Old Mar 19, 2009 | 01:11 AM
  #200
Dranom's Avatar
^^^ thanks for the info man!
Old Mar 19, 2009 | 10:14 AM
  #201
BostonG6spd's Avatar
if you are putting LED's in the blinkers, make sure you add a load resister to each blinker, or else your blinkers will hyper blink.
Old Mar 19, 2009 | 10:54 AM
  #202
Jazz4sho's Avatar
thanks for that info.
Old Mar 19, 2009 | 11:00 AM
  #203
TheDude's Avatar
Nice write up.. I need to do my vanity mirrors and my glove box, now I can.
Old Mar 19, 2009 | 07:55 PM
  #204
artsVQ's Avatar
thanks for the info FlSHRFun video helps out alot
you can change your glove box light and air filter at the same time
Old Mar 19, 2009 | 10:12 PM
  #205
artsVQ's Avatar
does anyone have pictures of crazy brite blinding reverse lights?
Old Mar 19, 2009 | 10:36 PM
  #206
FlSHRFun's Avatar
Well, I just ordered some LEDs for my reverse lights. They'll probably be here by Monday next week.
I looked up which bulbs they are, and Sylvania's website says they're "921" bulbs.
When I looked up what 921 bulbs looked like, they looked very similar to the "194/168/158" bulbs.
So... what I did was... I took the "194/168/158" LEDs from my license plate lights and stuck them in my reverse lights.
Guess what... it works.
The bulb I currently have in my license plate lights is very bright and pure white. No blue-ish hue to them.
It's a high power surface mount (SMT) LED.
V-LEDs.com is beginning to utilize SMT LEDs which are much brighter and have a much more pure white color. Rather than those less bright, blue-ish white LEDs.
I've purchased the following LEDs to install in my reverse lights:
http://v-leds.com/Interior-LED/DomeM...68710-1-2.html
The LEDs I currently have in my license plates are very similar to the ones here:
http://v-leds.com/Exterior-LED/Parki...11110-1-2.html
Old Mar 19, 2009 | 11:30 PM
  #207
artsVQ's Avatar
cool thanks for the info once again
Old Mar 20, 2009 | 03:56 AM
  #208
Dranom's Avatar
Or you guys can buy the 1 watts LED. its bright for sure. esp if you guys are doing the reverse ones
Old Mar 20, 2009 | 09:20 AM
  #209
what have you guys used for your blinkers? any suggestions on a nice bright LED? Pics?
Old Mar 20, 2009 | 09:52 AM
  #210
FlSHRFun's Avatar
^ +1, The 1 Watt LEDs are definitely bright. That's why I've bitten the bullet on the 1.5 Watt LEDs. Hopefully they're as bright as I hope.
