So close- Headlight removal????: already read DIY guide>>>???
Old Oct 16, 2008 | 05:18 PM
Rival's Avatar
So I have already gone through most of the steps. All clips are removed, all bolts are removed, bumper is free, and lights are only connected by their harnss.
My issue is I can't seem to get enough play in the head light to un hook the harness. Is there an issue tip or somthing I a missing?
Head light has all 4 bolts removed and still doesn't have much play.
Thanks for direction.
Old Oct 16, 2008 | 05:20 PM
officerdbag's Avatar
bumper off.
4 bolts..
Pull out.
undo 2 harnesses and you're set... The greyish one is easy to pull out.. the black harness might be just a tad tricky but not hard at all.
Old Oct 16, 2008 | 05:22 PM
surfwb86's Avatar
I had problems with the passenger side headlight, the wires didn't have enough play in them. I had to work with it but I eventually got it out. The driver side is 10 times easier, I use a flat head to give myself a little more force on the pin, then it slides right off.
Old Oct 16, 2008 | 05:25 PM
Rival's Avatar
It is the passenger one I am having issues with too. Did you have to go from under neath the light?
Old Oct 16, 2008 | 05:48 PM
wtf? what year are you're guys' cars?
Mine was an 03 and I had plenty of play/ room.. piece of cake.
Old Oct 16, 2008 | 05:56 PM
sfgr415's Avatar
Its always usually pretty hard the first time since there isn't much slack. When you re-install the headlights, I would advise you to leave slack in the even that you need to work on your lights down the line.
Old Oct 16, 2008 | 06:10 PM
WaLLy's Avatar
same thing I did. And yeah, the first time I removed the passenger side headlight harness was a PITA!
Old Oct 17, 2008 | 03:38 PM
surfwb86's Avatar
forgot which way I went the first time, I just remember having problems with it. After I got it out I freed up some room in the harness so it would be easier every time after that.
Old Oct 17, 2008 | 03:53 PM
patman530's Avatar
it might seem impossible to remove that clip at first with little room to move your hands, but just keep trying. there is a tab that you need to push on simultaneously while pulling the harness away.
Old Oct 17, 2008 | 04:20 PM
ttrank's Avatar
Grocery getter
I have not had any problems taking a number of people's lights off their G's. It's tight and I always used a 90-degree pick to unlock the clip.
Jusseth
Sep 13, 2020 12:25 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
skippyG
Jan 25, 2016 01:18 PM
yassy
Aug 9, 2015 07:31 PM
