3rd Brake Light
3rd Brake Light
Can someone give me instruction how to change the 3rd brake light lens on the stock spoiler. My lens has a big crak on it and I am not sure if I need to remove the whole spoiler or just the bottom piece w/ double sided tape. Thanks
2004 | 6MTs | Diamond Graphite/Graphite
Re: 3rd Brake Light
My coupe service manual says that you have to remove the spoiler itself to change the bulbs inside. Good luck...
2004.5 DG/G 5AT Coupe with all options
Sidemarker turnsignal mod
GroundingGear™
2003 Yamaha YZF600R
GroundingGear™
2003 Yamaha YZF600R
Re: 3rd Brake Light
If it is like my MX6, you just remove the bolts on the inside of the trunk, pull off the spoiler. There should be screws holding the light, just remove the screws and the pull out the light. I bought a replacement light from spoiler.com (I think if I remember correctly) You might go with a clear light. The one for my 6 was @ $50. that was way better than the $300 the dealer wanted for a factory light, and it fit perfectly.
2003.5 5AT
Premium Package
Tire/Wheel Package
K&N Filter, Z-Tube, EGK
2003.5 5AT
Premium Package
Tire/Wheel Package
FS[SoEast]: 2006 DG Coupe Part Out - mrev2, projectors, etc
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
