Circuit Performance 4300K White D2C Bulbs
Old Nov 12, 2008 | 11:11 PM
Calvin's Avatar
Overglorified Altima
I'm looking into alternatives to the Philips 5000K bulbs because I want pure white light. I don't want any blue/purple hue. The Philips 5000K look great, I've seen them in person. Pure white. But they're pricey. Anyone ever heard of these? Input?
IvoryGT? Ever heard of these?
Bulb Size: D2C (Replaces D2S or D2R)
Wattage Draw: 35
Average Luminance: 202500 cd
Color: White
Color Temp: 4300K
For reference, here is their 6000K
Circuit Performance D2C Xenon HID Bulbs - They're not Original Equipment (OE) replacement bulbs...they are better than OE replacement bulbs. Featuring a metal shock resistant base so they not only look great, they're also designed to outlast any xenon replacement bulb on the market.
If your vehicle is equipped with factory xenon High Intensity Discharge (HID) bulbs, you don't have to settle for boring white xenons. Circuit Performance offers your choice of six different colors to customize and enhance your lighting.
Upgrade to yellow, white, blue, or purple with no loss in lumens output. The key is specially formulated xenon gas blends that dramatically change the color output while maintaining a clear glass bulb.
If you are looking to upgrade your factory HID xenon bulbs, Circuit Performance HID bulbs are a quick, easy and affordable way to change the look of your car, truck, or SUV.
http://www.automotivelightingusa.com...d891d4f089fea6
Old Nov 12, 2008 | 11:19 PM
sfgr415's Avatar
I'm willing to bet those 4300K's will look similar to stock Phillips 85122+.
Old Nov 13, 2008 | 01:50 AM
Calvin's Avatar
Maybe, maybe not.
Old Nov 13, 2008 | 02:56 AM
ON's Avatar
ON
i agree. But if you don't think so Cal...you can be the first to try and let us know.
I think MTEC has 4500K bulbs if you want to try those. If you want a white white output, I believe a 5000k bulb is your best bet.
Old Nov 13, 2008 | 03:20 AM
Calvin's Avatar
If you guys are judging by temperature rating only, then I'd have to wait for some other responses. I've found that it is not a very consistent from brand to brand. 6000K is white here while it's blue there. 5000K is white here while it's yellow else where. Etc.
For example:
Their 4300K looks pretty damn white. But I'm concerned that the pictures are deceiving. It's very difficult to capture light on a camera the way it actually appears. It's also very easy to alter it in post processing.
Old Nov 13, 2008 | 11:27 AM
IvoryGT's Avatar
Pictures won't tell you anything and other than Philips I would be weary of what they say the K rating is, most is inflated. The actual rating will most definitely differ.
The price of Philips allows you to NEVER having to replace them for 3+ years. I seriously doubt any other company other than OSRAM or Koito can match the performance.
So if you pay for these at like 50 a pair...having to replace them every 6 months. I don't think 200 a pair for Philips that last 3 years is all that expensive.
Old Dec 17, 2008 | 11:08 PM
importroller's Avatar
what is the OEM output?
Old Dec 18, 2008 | 11:03 AM
MidnightG35X's Avatar
Right around 3100 lumens per bulb I believe (4300K temperature)
Old Dec 18, 2008 | 11:54 AM
redlude97's Avatar
3400lm for 85122+
Old Dec 18, 2008 | 06:42 PM
i tried a search, but I just want to brighten the output a little bit so they will be as bright as the 6K I have on my altima. is the bulbs Cal listed up top what I need to look for?
Old Dec 18, 2008 | 06:48 PM
ShanesG's Avatar
Just get the Philips, that's what ima get eventually!
Old Dec 18, 2008 | 06:58 PM
redlude97's Avatar
OEM is the brightest, anything else is going to result in less output, especially 6k like you have in your altima.
Old Dec 19, 2008 | 10:19 PM
my altima lights up more of the road than the G does. I can see way better in the Altima
Old Dec 21, 2008 | 03:34 AM
accordfreak's Avatar
85123 is 5000k pure white for mine.
as they say pictures are deceiving.
http://cgi.ebay.com/ebaymotors/Phili...Q5fAccessories
Old Dec 21, 2008 | 04:19 PM
redlude97's Avatar
85123's would be a good choice if you could still find them new. Since they were only put on a select number of early HID equipped BMW's, they are going to have significant hours on them and thus reduced output. Paying $150 for used bulbs with unknown hours would be a very bad idea IMO if you are concerned with output or longevity
