Lights
Old Dec 3, 2008 | 01:58 PM
tasurber's Avatar
Lights
All,
I have a 2003 G35 sedan and my side marker liight and parling light on the driver side are out. How do I change them and what bulbs do I need?
Thanks,
Tim
Old Dec 4, 2008 | 08:38 PM
topprospect16's Avatar
Pull the side marker out (may take a solid nudge)...twist the side marker to loosen it, pull it out...then you will see the bulb...take the bulb out...take it to autozone or wherever your heart desires...show them the bulb, tell em you need it replaced (I think its a 194 or 184 bulb maybe wrong though)...give them two dollars...take home and put back together
Old Dec 4, 2008 | 10:47 PM
tasurber's Avatar
Thank you. How do I pull and is the parking light, under the headlight, accessable then?
Old Dec 5, 2008 | 05:38 PM
just hold onto the top and bottom of the bumper and just pop out your side marker...the daytime running lights are a little more extensive to explain...check in the DIY section
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
cmesidewayz
Sep 29, 2015 09:28 PM
neight
Interior
Sep 21, 2015 05:35 PM
Jnm07
Sep 5, 2015 01:16 AM
