08- Replacing Fog light bulb
Old Jan 3, 2009 | 03:20 PM
ggaudreau's Avatar
I looked on the forum for some tips on replacing the fog light bulb but could not find one specifically for the 08. Some DIY talk about removing the inside wheel fender I can't think that Nissan would have there mechanics remove the inside wheel to replace a simple light bulb
Does anyone have any hits on replacing the fog lights on an 2008 G35.
Thx
Guy
Old Jan 3, 2009 | 05:44 PM
Borna's Avatar
To replace the fogs you just need to remove the air box/filter from the air intake by unclamping it from the intake tube, unplug the MAF sensor and pull it out.
Then just reach in and take out the bulb harness by turning it counter-clockwise and switch the bulbs.
Reverse the steps and you should be done.
Old Jan 5, 2009 | 10:55 AM
GR8TG35's Avatar
I'm not sure on the 08......but its not a big deal to go thru the fender well. It takes less than 15 mins each side.....I just replaced my Fogs on my 04 coupe. That is the only way I know to get at the back of the headlight housing short of dropping the front bumper...which takes a bit longer to do...... Did a DIY in this forum w/pics. Check it out and see if your car is the same.....
I'm not sure if you can just take out the harness by turning it....My fog bulbs are sealed behind a cover......it requires you to unscrew the cover to access the fog bulb.....
Old Feb 10, 2009 | 03:23 AM
Superchong85's Avatar
Does anyone know how to change an 07's fog light bulb?
Jusseth
Sep 13, 2020 12:25 PM
Freddy07g35
Sep 17, 2015 08:53 PM
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
attarday
Jul 15, 2015 04:03 PM
