LED swap question
Old Jan 20, 2009 | 04:37 AM
loki05's Avatar
LED swap question
Hey I wanted to swap the led in my 2005 G35, but i just had a few questions
1) For the gauge cluster, the numbers such as the rpm or speedometer have orange film on the front, and for the lines they have the orange film on the back which you can sand off easily, I am keeping the lines on the gauge white so I am using white leds, but the front numbers if i wanted those to be blue would i need to put a blue film behind it?
2) On the odometer, If i wanted the numbers to be white and the background to be blue would I need white leds and blue film?
3) I could not take the radio circuit board fully apart from the radio. I assume that you would have to probably take the temp **** and volume **** off? But I tried pulling it off and it wouldn't come off, is there anything special I have to do to take the circuit board off of the radio?
Its a 2005 g35 coupe, and I could not find anywhere in the search on how to remove the circuit board off the radio.
BTW how do I remove the circuit board off of the clock if you guys dont mind me asking.. Thanks a lot!
PS if anyone knows what size the small leds are for the seat heaters and trunk opening button, door handle buttons etc. that would be great also
Old Jan 20, 2009 | 07:07 AM
vhtran's Avatar
https://g35driver.com/forums/g35-cou...rsion-kit.html
Old Jan 20, 2009 | 08:49 AM
same olg's Avatar
Temp ***** must come off, then unscrew the board off the trim also if i remeber correctly the flat wiring strip at the bottom slides out
Old Jan 22, 2009 | 02:48 AM
loki05's Avatar
thanks for the help but i still could not find how to remove the orange film
on the gauge cluster such as the digits. the film is on the front of the gauge cluster instead of the back for the 05+ clusters, anyone have any clue how to deal with this?
Frostbite91
Aug 12, 2015 05:16 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
