Low Beams are not working
Old Jan 28, 2009 | 07:25 PM
Mystic Eyes's Avatar
Question Low Beams are not working
Okay so here is the thing, Just got the car and low beams are not coming on i figured that if neither of the lows were coming on it probably wast just a bulb! ( could be wrong) What do you suggest! Fuse maybe? Or what? Where do i find the fuse if it is that? Please help!
Old Jan 28, 2009 | 08:25 PM
redlude97's Avatar
if both went out at the same time, it is most likely a fuse. Check the ones that are hidden behind the battery if none of the ones in the kickpanel by the brake pedal are still good
Old Jan 28, 2009 | 09:28 PM
Thanks much I'll check that out!
Old Jan 29, 2009 | 07:25 AM
vhtran's Avatar
They took the ballasts hehehe j/k j/k but it could happen =)
Old Jan 30, 2009 | 04:57 PM
Problem FIXED!! It was 2 fuses in the fuse box behind the battery! Thank goodness! All is well now!
Jusseth
Sep 13, 2020 12:25 PM
julian.dion
Lighting
Jul 29, 2015 12:47 AM
joedaddy1
Jul 28, 2015 02:58 PM
EasySausage
Jul 20, 2015 03:56 PM
