Those that have modified their headlight clearance strip
Old Feb 18, 2009 | 05:23 PM
BostonG6spd's Avatar
For Those of that have modified their headlight clearance strip what is the best LED strip to go with. I know that some have made their own LED board, but i dont want to mess with soldering. Im thinking about something along the lines of this flexible LED strip:
But im woried that it wont be bright enough.
What would be the brightest strip that people have used, and where did you purchase it from?
I was also wondering where you guys mounted the strip.
Thanks in advance
Old Feb 18, 2009 | 05:28 PM
Foques's Avatar
I tried these
http://www.oznium.com/led-flex-strips (were too thick)
and ended up using these
http://www.oznium.com/thin-led-strip
bright enough.
Sorry, no pics yet..
Old Feb 18, 2009 | 05:30 PM
MTG35guy's Avatar
I wish someone would do a DIY on this. I wanna do it.
Old Feb 19, 2009 | 02:39 PM
any other inputs?
Old Feb 19, 2009 | 10:08 PM
alexcaro's Avatar
I purchased a slightly flexable circuit board and solder 16 1.8mm leds into it.
I did pair them in 4's and added a resistor so they would emit their light evenly, and also for safety.
As for the headlight, I opened it up, took the cover out Used a dremel to make the led fittings through the back. Clean install.
Old Feb 19, 2009 | 10:39 PM
Convert35's Avatar
+1, I wanna do my clearance strip and my clear corners in LEDs one of these days
Old Feb 24, 2009 | 10:50 AM
any more inputs?
Old Feb 24, 2009 | 02:57 PM
nutt's Avatar
any pics?
Old Feb 27, 2009 | 12:06 PM
come on guys, i know that theres so many of you that have modefied the strip
Old Feb 27, 2009 | 01:05 PM
visibiliti's Avatar
Ok I am either going to use these:
http://www.oznium.com/led-ribbon
or use my luxaura light guides i ordered and light them with a 168/192 socket forward facing LED cluster I got from VLEDs that would be plugged into the city light socket.
haven't decided yet, will get more time to work on the project this weekend and if i get far ill try to post pix next week.
Old Mar 9, 2009 | 01:24 PM
chering88's Avatar
DIY! DIY! DIY! Si se puede!
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
