led conversion
Old Mar 10, 2009 | 04:56 AM
g35cam's Avatar
led conversion
Hi, I check the DIY section and used the search but couldnt find a how to for these. I want to convert my clearance strip and side markers to LED... anyone have a write up on how to?
Thanks
Old Mar 10, 2009 | 12:10 PM
chering88's Avatar
there she go slidin down that pole
gotta search in the DIY section
https://g35driver.com/forums/body-in...hid-bulbs.html
Old Mar 10, 2009 | 01:42 PM
g35cam's Avatar
thanks, im just trying to figure out how you do the wiring, do you quick splice them into the existing ones, and how do you get the strip in there, do you glew it in there?
thanks
Old Mar 10, 2009 | 02:45 PM
chering88's Avatar
if youre looking to just change the one bulb that comes stock then you dont need to do anything, if you are trying to add a strip of leds then there is a different thread...
https://g35driver.com/forums/g35-cou...eadlights.html
hope this helps, its def not as simple as the conversion i thought you were doing
GL
Marlin84
Apr 1, 2020 12:52 PM
g.spot
May 9, 2016 10:54 PM
Extreme Dimensions
Exterior-Vendor
Oct 29, 2015 10:24 AM
Gabe83714
Oct 6, 2015 06:40 AM
twentyeggs
Sep 11, 2015 03:58 PM
