Hyperblinking Question
Old Mar 30, 2009 | 04:45 PM
xjonmo's Avatar
I recently got a set of 06 headlights w/ LED turn signals. Since the LEDs cause the turn signal to hyperblink, I installed load resistors on both sides. However, only one side works (L) and the other still hyperblinks(R).
I tried switching out the load resistor for another one and it still does the same thing. Then I tried taking the head light that had hyperblinking fixed (L) and plugged it in on the broken side (R). That one started to hyperblink too.
It seems as if there is something wrong with the right side of my car or something, but I'm not sure what it could be. I never had this problem before so I'm not sure where to start.
Thanks for your advice
Old Mar 31, 2009 | 10:59 AM
MidnightG35X's Avatar
What value are your resistors?
Old Apr 1, 2009 | 12:03 PM
BostonG6spd's Avatar
did you take the headlights out in order to put the resisters in? Im trying to do the same thing, but im not sure which wire to tap into. do you have any pics?
Thanks
Old Apr 1, 2009 | 12:05 PM
ShanesG's Avatar
you sure the LED works???
Old Apr 8, 2009 | 10:13 PM
xjonmo's Avatar
yup it all works...just blinks fast. no idea why
i'll take a look at the value of the resistors tomorrow. i don't remember off the top of my head, but both of them are them same. i made sure of that. it just doesnt make sense that one would work and the other doesnt
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
