4300K vs 6000K
Apr 5, 2009 | 03:01 PM
I cant seem to pick which i want to buy, 4300HID or 6000HID. I think the oem is usually 4300K.
what do you guys think?
Reply 0
Apr 5, 2009 | 03:05 PM
do you want looks or performance?
Reply 0
Apr 5, 2009 | 03:06 PM
4300k is the OEM which does offer more light output than the 6000k. However 6000k looks much better IMO b/c it's more "whiter" w/o the hint of yellow.
Plus the light output lost is not going to be really noticeable. I'd go w/ the 6000k HID.
Reply 0
Apr 5, 2009 | 03:20 PM
Quote: 4300k is the OEM which does offer more light output than the 6000k. However 6000k looks much better IMO b/c it's more "whiter" w/o the hint of yellow.
25+% isn't noticeable?
Reply 0
Apr 5, 2009 | 03:27 PM
wow, the light output lost is def noticeable w/ 6000k... and more "whiter" ??? 6000k is much "bluer"..!
To the OP.... go 5000K!!! its the best
Reply 0
Apr 5, 2009 | 06:23 PM
I'm looking more for light output and performance is the last thing. So 6000K is not going to work! 5000 would be sweet, it will be middle of 4300 and 6000k.
I;m going to place an order from either retrosolutionsllc or XenonDepot. Retrosolution offers 55W/lifetime warranty along with 35W. My car is currently running halogens which are 55W stock, so im guesing 55W HID wont heat up.
"55 watt HID that uses 55w bulbs still runs cooler than a 55w halogen bulb it generally replaces, to replace any other lower wattage halogen bulb we recommend 35w instead. So 35w or 55w, properly installed, stands less risk of melting housings than the bulb they replace"
However both compainese are well known, i'm leaning towards 55W just because of the light output, but just not sure if i should play it safe n get the 35W.
Sorry for the long post...
Reply 0
Apr 6, 2009 | 03:00 AM
Quote: 25+% isn't noticeable?
If you do most of your driving in the city where there is plenty of street light, 6000k will provide sufficient amount of light output for daily driving.
Reply 0
Apr 6, 2009 | 03:14 AM
Quote: If you do most of your driving in the city where there is plenty of street light, 6000k will provide sufficient amount of light output for daily driving.
Sufficient is not the same as noticeable. Halogens are sufficient as well
Reply 0
Apr 7, 2009 | 04:49 PM
found this website prices seem fair i think. and they also have 5000
http://intensehid.com/d2c.html
Reply 0
Apr 7, 2009 | 04:54 PM
I'd go 6000k. They look sweet And on my projectors, can't wait to get mine...... But go to the meets and check out some of the other fellow G drivers cars that have HID's.
Reply 0
Apr 7, 2009 | 05:02 PM
Quote: wow, the light output lost is def noticeable w/ 6000k... and more "whiter" ??? 6000k is much "bluer"..!
Definitely go 5000k, which is natural white, no yellow nor blue. i put my in about 2 weeks ago, really good lights,
2003-2006 Reflectors
2007+ Projectors
http://www.aftermarketbulbsshop.com/...phi-cm-d2s.htm
Reply 0
Apr 7, 2009 | 05:15 PM
6000k ftw!
Reply 0
Apr 7, 2009 | 05:41 PM
4300K or 5000K. 6000K is getting too blue imo. The most lumens (visable light output) you will get will be from 4300K bulbs.
Reply 0
it all comes down to this:
white with a hint of blue or blue with a hint of white?
Reply 0
Apr 7, 2009 | 09:28 PM
So i ended up just placing an order with retro-solutions.com . The customer service was A+. I went with the 55W 5000K, The reason i decided against the 6K was cuz i want to keep my car close to stock.
I will post pictures soon as i get something
Reply 0
