06 projector wiring HELP!
Old Apr 23, 2009 | 09:12 PM
repin_LB's Avatar
NEED HELP! Hey guys so i just wondering how all this wiring works out. I have a set of the 06 projectors goign to upgrade from the 03 and i was confused in how to connect all the bulbs and where.
1st- The HID headlights do i just use the 03 ballast to connect it to the d2s bulb when i take apart the 03 housing?
2nd - The fog housing there are like 3 wires, 2 black and 1 yellow, which wire do i connect it to the fog bulb?
3rd - where is the city light marker and where does that go? its the 194 bulb correct?
4th - signal light which i already know where that is
i was also wondering if the mtec h1 4750k bulb will work with the stock 06 projectors? as in will it just be a plug in play or would i have to get a HID conversion kit for the fogs also.
Here are some picture to give you guys an idea what im trying to ask
this is the fog light wiring im confused about
And are the side markers connected to the corner lights?
The headlight housing there are no connections to connect to the bulb so when i take apart my 03 headlights do i just use the old connections?
Old Apr 27, 2009 | 03:36 AM
repin_LB's Avatar
BUMP help
Old Apr 27, 2009 | 04:09 AM
redlude97's Avatar
let me guess, recalled headlights?
Old Apr 27, 2009 | 12:30 PM
visibiliti's Avatar
lol, ill bite.
1) Unscrew the ballast off of your '03 HL housing. Now unplug and unscrew the ignitor wiring connected to the inside of the ballast, and pull the ignitor out through the opened top cap. Reinstall this into your new '06 HL housing in reverse order, then plug/screw back into the ballast, and screw the ballast onto your '06 housing. You are correct, the ignitor will now attach to your D2S bulb, which goes into the back of the projector base seen in Pic#3 through the upper cap.
2/3) There are 4 wires, not 3. The two wires that are "connected" together, that come together into a black plastic housing at the ends... this is where your city light bulb goes. the 168/194 socket. The other separate black and yellow wires with the plastic covers at the end connect to your H1 bulb, which inserts into the back of the reflector bowl behind the lower cap.
"i was also wondering if the mtec h1 4750k bulb will work with the stock 06 projectors? as in will it just be a plug in play or would i have to get a HID conversion kit for the fogs also."
Your foglights, the H1 bulbs, are not HID, therefore yes they are plug n play.
Old Apr 27, 2009 | 07:36 PM
repin_LB's Avatar
thank you visibiliti! but the fog bulbs that i have only have one notch on it so how does the yellow and black wires connect to it?
Old Apr 27, 2009 | 10:26 PM
visibiliti's Avatar
Oh, yea yea you're right, sorry I forgot.
If you look through the lower cap on the back of the HL housing, inside you will see the back of the reflector bowl, there is another tab sticking out of it. This is for the ?ground? (black) and the tab on the H1 bulb is for the ?power? (yellow).
I put ?marks because I am not sure if it's like this or the other way around... I forgot. sorry...
Old Apr 27, 2009 | 11:25 PM
repin_LB's Avatar
NO helped me alot visibiliti. Didnt even noticed that little ground notch until you mentioned it. Much help!. Will get on this replacement this weekend
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
9tray turbo
Sep 29, 2015 10:22 PM
