HELP!! (don't buy from v-led)
Old Apr 29, 2009 | 06:59 PM
The-Dream's Avatar
Originally Posted by cthrulies
I've replaced most interior lights, side marker, clearance bulbs and license plates with VLED's without a problem. These tips should help.
Return everything to stock bulbs.
Replace with VLED bulbs 1 at a time.
Test each bulb before you reassemble components.
A VLED bulb will not work if the polarity is reversed.
Make sure that the bulb's lead are aligned correctly in the socket.
Disconnect then reconnect the neg battery terminal if things act weird.
It turned out one of the turn signals kept blowing the "tail light" fuse. I had to use pair of needle-nose pliers to make the little metal pieces (not sure what they are called) on the bulbs straight so they don't touch the other copper pieces inside the socket. However I still have a few problems they persist. I can't believe so many things are connected to that one fuse.
Old Apr 30, 2009 | 12:21 AM
Cloud_35's Avatar
What other problems are persisting?
Old Apr 30, 2009 | 08:06 AM
The-Dream's Avatar
My dome lights, sunvisor lights, and my signals are not blinking.
Old Apr 30, 2009 | 01:48 PM
The-Dream's Avatar
I'm thinking I might have to try the resistors that V-LEDs use. Does anybody know how I can get to the BCM?
Old May 8, 2009 | 01:20 PM
The-Dream's Avatar
I installed the resistors and it still doesn't work.
Old May 8, 2009 | 01:27 PM
06g35meister's Avatar
Ya i was gunna say the resistance of an LED is not the same as an incandescent. Line resistors should fix the blinker problem, the dome and sunvisor lights are most likely a fuse blown.
Old May 8, 2009 | 05:43 PM
The-Dream's Avatar
The resistors seemed to do nothing, once again they stay on but won't blink.
TheJanitor6203
The Q - Spot
Oct 6, 2015 10:13 AM
Gookiecrunch
Aug 19, 2015 12:00 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Karnicle
Jul 23, 2015 05:08 AM
