Another problem...headlights!
Old May 22, 2009 | 05:44 PM
Mo's Tre' 5's Avatar
NOW this one is my fault...i used Goof-Off to remove the sticky stuff left over from bat's overlays and this is what i got leftover....next time ill read the instructions first!!.....LOL!!!...it clearly states DO NOT use on certain plastics...............................wondering if anyone has a hookup on 06 projectors or just 03 left headlight?????.....
Attached Thumbnails Another problem...headlights!-headlight1.jpg   Another problem...headlights!-headlight2.jpg
Old May 22, 2009 | 05:49 PM
elayman's Avatar
have you tried hitting it with a polish/wetsand/or plastX?
Old May 22, 2009 | 06:04 PM
PPGFREAK's Avatar
pm "Iron-Mike" and he will do crazy things with your lights
Old May 22, 2009 | 07:35 PM
ima try some spray they use to remove **** off our blackhawk windows...hopefully that wrks..man does it look horrible!...LOL
Old May 22, 2009 | 09:19 PM
WRAH's Avatar
WRAH
Its going to take a lot of work, but you can reverse this.
1st use a rubbing compound to, in effect, sand the chemical stain off the top layer of plastic. Then you have to polish it with a plastic polish. Best done with a machine, not by hand, and avoid heat!
I believe you killed the film that provides UV protection to the plastic. You will have to repeat every now and then to avoid a haze now that this film is gone.
Old May 22, 2009 | 09:39 PM
the1cyrus's Avatar
See if this helps any:
Old May 23, 2009 | 01:41 AM
yea i need to get a buffer machine...LOL..BUT i think my headlights are done..cause i used the sandpaper/wax kit that u can buy..it didnt do anything but killed my fingers...LOL
