Bought Hid replacement bulb and not working.
Old May 22, 2009 | 04:37 PM
nctrnlsilvia's Avatar
I bought a replacement bulb for my o4 coupe with HID and it doesn't work. The box says PHILIPS XENON LIGHT. Its a D2R bulb. Is it because its a Xenon bulb?
Old May 23, 2009 | 10:10 AM
How can you tell if the BALLAST Is broken?
Old May 23, 2009 | 12:10 PM
sfgr415's Avatar
Lets see here.
A D2R is the correct bulb for a 2004 coupe headlight assembly. I am 99% sure all coupes came with HID. You can always check the outer lens of the headlight to confirm it is a D2R application.
Are you just replacing one side? Try this.
-Try to install the new bulb on the other side and see if it works. If it does, there is something wrong with one side, possibly the ballast.
Old May 23, 2009 | 06:42 PM
I just did that and its not the bulb. The bulbs are fine. I think its the ballast. Im going to have to buy new headlights because that one was leaking,and I just found a hole on the fog light cover. So that must be where the water came in from. I fix one thing something else happens. it never ends with, this car. Unfortunately I love driving it too much to part ways with it.
bTanz
Oct 15, 2015 02:31 PM
kd03g99
Jul 30, 2015 11:24 AM
julian.dion
Lighting
Jul 29, 2015 12:47 AM
attarday
Jul 15, 2015 04:03 PM
