LED lights dying
Old May 22, 2009 | 09:16 PM
the1cyrus's Avatar
LED lights dying
Im having a problem with my led lights starting to flicker and then die. I think it has to do with over voltage. My g35 is a 2004 coupe. I tested the voltage with the car on and off and i found that when the car is on another 2 volts is added to a total of 14 volts. it should stay around 12volts for the leds. Anyone know where the fuse might be for the front side marker lights and the front clearance lights?
FYI: The dome light fuse is inside left of the drivers side.
I plan to add a resistor shown here: http://stores.shop.ebay.com/US-Home-...r-Flasher.html
ts a 25 Ohm, 25 Watt Load Resistor. Think that's enough? just trying to lower the voltage when the car is on.
Old May 30, 2009 | 12:45 PM
the1cyrus's Avatar
anyone have a clue? or does anyone know a better way of getting the voltage down from 14 volts?
zoop425
Mar 29, 2016 05:51 PM
mtlruss
Dec 20, 2015 01:51 PM
Silver tiburon
Sep 4, 2015 07:17 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
