Flexible LED Strip Help
Old May 23, 2009 | 02:50 PM
bmpnride's Avatar
Question Flexible LED Strip Help
I know many of you have used flexible strips for projectors. I have some 8mm wide ones but it appears that some have some strips that are less than that. Please let me know where I can find these thinner ones. It appears that clearcorners.com uses thinner strips. It could also be that the strips were just mounted farther back toward the lens with only part of it mounted to the shroud. Please see pic for what im talking about.
Old May 25, 2009 | 02:34 PM
bmpnride's Avatar
I know someone has to have an answer for me.....
Old May 25, 2009 | 11:24 PM
alexcaro's Avatar
In my opinion placing led strips over the headlight looks cheesy. I have dremeled small holes and placed small leds inside headlights to obtain a cleaner look.
Old May 26, 2009 | 05:20 PM
bmpnride's Avatar
Lets see a pic of your headlights. The shroud is not very large to work with so placing individual LEDS is not the easiest, unless you have tiny hands...
Old May 28, 2009 | 12:24 AM
alexcaro's Avatar
Yes, you are right. I thought you were referring to the strip side.
The shroud is difficult to drill into but can be done, hardest part is wiring all the leds inside that small area.
I tried and it took me a long time to complete, therefore it was not worth it for me to start the other headlight.
Other companies and members have use strips. The shroud is not a straight circle though and some strips may have small gaps around the projector shroud.
Old May 28, 2009 | 12:26 AM
alexcaro's Avatar
I dont have any pictures of the shrouds with leds as I never complete those headlights but these are some others I have completed.
leds on the side and inside the turn signal. The amber is the small stock fog bulb.
Old May 28, 2009 | 02:39 AM
bmpnride's Avatar
Your sides look like how mine will look. Im getting 20 5mm LEDs drilled into the clearance strip where the middle peak is raised. The LED shroud is pretty bright from the test fit. Cant wait to get it completed and installed. Image shows alot of light cuz my my camera phone is not the best.
Old May 28, 2009 | 03:22 PM
alexcaro's Avatar
Hard to see the details but color and idea looks good so far.
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
g.spot
May 9, 2016 10:54 PM
NailBomb
Oct 28, 2015 07:53 AM
Gabe83714
Oct 6, 2015 06:40 AM
