Quick Question on Signal Lights
Old May 31, 2009 | 10:11 AM
Unrecognized's Avatar
I noticed recently that my lights look different from everyone else. My orange signal light is never on except when signaling. Normally I see the headlight and the orange light on other G's, but not on mines. Any idea on how to fix that? I have a 2006 coupe 5at.
Old May 31, 2009 | 09:58 PM
dave's Avatar
The earlier coupes came with different headlights. The earlier ones had reflector (instead of projector) HIDs for the headlight, and had orange running lights that doubled as turn signals.
You are probably seeing earlier model coupes (2003-2004).
Old Jun 1, 2009 | 01:45 AM
FlSHRFun's Avatar
2003-2005 coupe headlights have 7443 (dual-filament) bulbs in their turns signals. So the dim filament is on with the parking/headlights and the bright filament is on when signalling.
2006-2007 coupe headlights have 7440 (signel-filament) bulbs in their turn signals. So, they only illuminate when you signal.
If you want to fit a 7443 bulb in there, you'll need to follow this DIY:
https://g35driver.com/forums/body-in...-housings.html
Old Jun 1, 2009 | 03:40 AM
Thanks for the info guys. I think I'll get the 7443 bulbs then.
Old Jun 1, 2009 | 12:18 PM
FlSHRFun's Avatar
Just putting in a 7443 bulb won't make it illuminate with your parking lights and signals.
You'll need to replace your 7440 connector with a 7443 connector and splice in a few wires.
It's not simple plug & play.
Old Jul 15, 2011 | 02:53 PM
hdmark's Avatar
bump to know which wire to clip to eliminate the low illumination running lights part of the bulb?
Old Jul 15, 2011 | 03:20 PM
saywat?'s Avatar
^cut the pair of inner wires on the bulb
Old Jul 15, 2011 | 07:44 PM
hdmark's Avatar
thanks!
chinee
Jun 10, 2024 07:48 PM
Muski_G
Dec 1, 2023 11:11 AM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Tylerttn
Jul 14, 2015 10:11 PM
