tail lights out, and inside lights
Old Jul 11, 2009 | 10:40 AM
crazeejitt's Avatar
well last night I noticed my inside lights to my radio buttons nor airconditioning buttons nor my clock light worked. then the person behind me found out neither do my tail lights, and I found out my side markers do not work. maybe a fuse blown that anyone knows about? Good thing is my brake lights work, front lights works, turning signals work.... im mainly concerned about the tail lights. I know its no bulbs. oh and the speedometer light works
Old Jul 11, 2009 | 11:00 AM
PAIXAO's Avatar
Have you even gone out and tried pulling your fuses? I would start there first.
Old Jul 11, 2009 | 12:47 PM
crazeejitt's Avatar
yes I did everything seems fine
Old Jul 11, 2009 | 03:04 PM
FlSHRFun's Avatar
Had the exact same problem, twice when working on the lights of my car.
It's a blown fuse, and it's a simple fix. This fuse isn't the fuse box by the dead pedal or the one in front of your battery.
There's a fuse box behind and below the battery that needs to be replaced.
Here's a write-up:
https://g35driver.com/forums/audio-v...use-blown.html
Old Jul 14, 2009 | 10:19 AM
crazeejitt's Avatar
that totally worked thank you so much FISHFRun
mike730
Jan 12, 2018 04:25 PM
G35forlife21
Aug 26, 2015 07:34 PM
roboeclipse
Lights
Aug 13, 2015 10:45 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
