Looking for help with the projector screw.
Old Oct 16, 2009 | 11:35 AM
crazeejitt's Avatar
I took my headlights apart a few weeks ago painted them and noticed that the projector screw has 3 tabs and 1 broke so it seemed to be hanging down. I took them apart very carefully in my room and I assumed that it was already like this because I could not find the tab anywhere. I assume that it was the pressure of the screw holding the projector up. Now that the headlights are back together the projector is aimed a little bit upwards and looks as if 1 of my brights are on. Luckily I do not have to drive at night but I am wanting to fix this asap. so if anyone can find me a screw. or even a casing (no bulbs no ballasts) that would be wonderful. It is a complicated screw, the one that you adjust the heighth of the projectors with. here is a pic
this screw
Thanks for all your help. ps:i checked http://www.carpartswholesale.com/cpw...car-parts.html
http://www.infinitipartsusa.com/spla....cfm?siteid=55
...no luck
Old Oct 17, 2009 | 04:10 AM
visibiliti's Avatar
The screw thread itself is an M5, if that helps you. Maybe you could get M5 threaded rod and find a way to attach it to the aiming disc mechanism at the back of the housing.
Old Oct 21, 2009 | 09:33 AM
crazeejitt's Avatar
bump
Picture Share
Feb 4, 2018 12:41 PM
lil beezy
Lights
Nov 16, 2015 02:52 AM
MrIP35
Oct 25, 2015 11:13 PM
alessandro
Oct 8, 2015 09:29 AM
