Project: LED MODS (part3) Finished Gauge Cluster
Socal LED Project
I just received some blue Led's in the mail and im going to start the soldering process. I live in Downey CA and I plan on taking pictures and showing the results. I dont know how to start my own thread so ill prob just post it here.
took about 5 hours and I'm good with soldering. Not going to do a DIY, this isn't really DIY material. I do suggest looking for post by me and accordfreak and get some knowledge in electronics before you start.
I've been working with LED's and electronics for around 8 years now. I don't know how someone with out even a year of experience would be comfortable with touching their car's sensitive electronics before testing on many other things (which would remove the need for a DIY)
i have an 04 and its 130am now... how the heck do i change out the leds on my compass/ac/temp gauge/screen??? i dont see any leds under the lcd display. they have to be inside of the glass itself??
I agree with SexyRob. I don't recommend a DiY because you might fry your console if you don't have experience. I'm an engineer student and know a lot about electrical components. It took me a day to do on and off. Some led's were dim and had to be replaced. Ill post pictures soon
thanks to op and accordfreak. had to dremel out the amber part of the cover and purchased a smoke pink and a "minus green" pink film as the display on the 03-04's light up green after the amber is cut out. my display is now white..
after seeing what you did will LEDS on door, i decided to try it too...i used blue LED's instead since my exterior color is brilliant silver and thought blue would look a little better...check out some posted pics at
https://g35driver.com/forums/g35-cou...tall-pics.html
