Ballast or bulb? Help please
Old Jan 26, 2010 | 02:33 PM
nlallen141's Avatar
I was in a minor collision that broke a few mounting tabs and knocked my turn signal bulb out of it's socket. That's all fine, I fabricated some new tabs and fixed the bulb. My problem occured when I was hookin everything back up. I mounted the headlight and turned kn the lights without connecting the said fixd light fixure, after a short panic then quickly noticing my mistake I powered everything down and connected everything. Upon turning everyhin back on my other (not the one I fixed) hid light sputtered and failed to ignite. After a thorough look of wiring to ensure everything was plugged in, I reall started to worry. Now the light I fixed is in perfect working order and the light that I didn't even touch will not ignite it's hid component (hi beam fog and turn still work). Any help? Suggestions?
Old Jan 26, 2010 | 02:58 PM
WILLIE BEANS's Avatar
switch the low beam bulb with the other working one .. if it turns on ...then its the other bulb thats blown .. .
if it doesnt turn on then its the ballast ..
jeffbdye
Jun 1, 2018 03:51 PM
lil beezy
Lights
Dec 23, 2015 05:25 PM
lil beezy
Lights
Nov 16, 2015 02:52 AM
Gabe83714
Oct 6, 2015 06:40 AM
twentyeggs
Sep 11, 2015 03:58 PM
