need some electrical help pls
Old Jan 25, 2010 | 03:44 PM
willcho415's Avatar
last night my friend with a ricer del sol wanted me to help add 2 pairs of fog lights into his car (yes, total 6 lights in front bumper with 6 hids). I agreed to help him and was going to wire it through a relay to a switch but he insisted on tapping into the headlight wiring just because it will save a lot more time. I told him that it was not a good idea but I ended up doing so. I wired the first pair of fogs including the hid (35w) with the headlight. Now, his headlights are hid also and hes running 55w on them. Once i wired both sides up, we turned on the headlight which turned all the headlights and the first pair of fog lights on. After about 5 seconds, they turned off. Now, even if we put back stock wiring, the headlights will not turn on at all. It seems like no power is coming to the lowbeam wire except for his high beam wire.
I came up with the possible issues but I would like more inputs on this as he wants me to fix this issue since i was the "installer". I warned him in the beginning -.-
Old Jan 25, 2010 | 03:51 PM
jthomas_50's Avatar
sounds to me like you blew the ballast....just a guess though
Old Jan 25, 2010 | 03:53 PM
willcho415's Avatar
the ballast is fine, because i have tested it in my other friend's car. :P
i think that it could be:
1. fuses
2. fried wires
3.
i thought it was bulbs or the ballast gone but i tested them out and all was good
Old Jan 26, 2010 | 03:52 PM
DiGil's Avatar
The first place to look would be the fuses, easy enough to check. You tried to pull too much power and burned them.
Old Jan 26, 2010 | 04:02 PM
TroysG's Avatar
^Ding winner
also call your friend a dummy for wanting to save time instead of doing it right the first time... also is he planning on putting the del sol in rallies?
Just wire them in properly. I'd suggest fresh fused wiring from the battery/ignition on their own switches. By this I mean soldered, fused and wire loomed.
I can taste the rice... and I haven't had chinese food in over a month
Old Jan 26, 2010 | 10:40 PM
willcho415's Avatar
thanks troy. i honestly hate how he wants me to help him install all these weird shti into his car. lol. last time i had to help him wire his little neon kit for underneath the dash to blink while the music plays. **** gave me a headache and he loved it. now he just got himself a bodykit that BARELY fits his car looks rice as **** hahhaha
Freeman186
Sep 6, 2023 10:07 AM
Danielek
May 1, 2022 01:28 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
vamarris
Sep 26, 2015 12:56 PM
