04 reflectors to 06 projectors... city lights question.
Old Mar 12, 2010 | 12:26 AM
parhamm1's Avatar
I know this has been covered and I've searched, but I can't find my answer. I don't know what the hell I'm missing and this may turn into a very stupid/simple answer. Question is as follows:
Installed some 06 Projectors today and threw some luminics H1 yellow fogs as well as a 6-LED 194 wedge bulb for the city lights. Got them all installed and while installing I run through the functioning testing by turning lights on/off and then fogs, etc before I tighten them all down and throw the bumper back on. I thought when I would turn just the driving lights (side markers and what used to be the turn signals in the 04 headlights) that the city lights would then come on. Anyway, flip on the driving lights and nothing but the side markers turn on. What am I doing wrong? I'm no noob to this car or modifications to this car, but now I'm just perplexed.
If this is a simple answer I would love to hear it so I could initiate self face-palming.
Thanks folks.
Old Mar 12, 2010 | 12:28 AM
nyckid's Avatar
that happened on my friends car too, its like the city lights are suppose to come on the same time as the clear corners, but instead they only come on when the headlights or turned on all the way.
but when i installed my projectors, everything worked like it should, so im not sure why his did that.
Old Mar 12, 2010 | 12:33 AM
parhamm1's Avatar
Strange. I don't get it either. What am I doing wrong here...
Old Mar 12, 2010 | 12:35 AM
MTG35guy's Avatar
Try turning the bulb an putting it in the opposite way, sometimes LED's will only work when placed in the shroud a certain way, at least that's how my 194's were.
Old Mar 12, 2010 | 12:38 AM
parhamm1's Avatar
Makes sense. I thought about this a little while ago. Any other suggestions or is this a pretty viable solution?
Old Mar 12, 2010 | 02:09 AM
felixsc300's Avatar
This is the most likely culprit, my license plate LEDs wouldn't work unless they were removed and reinstalled the opposite way.
Old Mar 12, 2010 | 10:58 AM
parhamm1's Avatar
Thank you sir. Going to be annoying to take the bumper off and the lights out again just to get the city lights to work, but I got that job started and completed in under 45 minutes now (hand tools).
Thanks again folks.
Old Mar 18, 2010 | 06:08 PM
twalls's Avatar
CLUB MODERATOR
You don't have to take the bumper off to get to the city light.. Go through the wheel well.. Jack up the front side of your car on that side just to give yourself room. Don't let the wheel get off the ground.. Turn the wheel all the way to the right, if you're on the left side, or all the way to the left if you're on the right side.. That will give you ample room to unclip the inner wheel lining and pull it down to expose the back housings of the headlight.. then you can reach it that way..
I agree. this is probably the most likely reason your LED city lights aren't working..
Hope this helps make it easier for you to flip them around.
Old Mar 21, 2010 | 01:00 AM
WTF??'s Avatar
^ great suggestion, but its a PITA to get in there!! You seriously have to have SMALL hands/fingers
If using this route, I think the next problem is puzzling your hand/fingers into the back of the headlight and UNclipping that city light from the socket
Worth a shot though!
Old Mar 21, 2010 | 01:38 AM
twalls's Avatar
CLUB MODERATOR
Actually w/ the wheel jacked up to raise the fender well, you have plenty of space to get your arm in there.. I have pretty big arms and can get my whole forearm in there.. I know where the plug is w/in the fog light housing, so I can grab that.. Then when you have the bulb on for the city light, it's easy to look around to the front of the headlight, while your arm is still in the fender well, and see where you're placing the city light housing to get it aligned in the hole.. It's all about feel I guess..
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
realtalk21
Jul 20, 2015 09:07 AM
