Interior lights not working :(
Old Apr 20, 2010 | 06:07 PM
Gorg3ou5's Avatar
all my dome lights in my 03 g35 sedan arent working.. since my cousin accidently tugged on the passenger sun visor too hard, all my light wouldnt turn on the wire connected to the visor ripped...
could that be the reason why all lights aint working? or could it be some fuse?
i checked all fuses in 3 areas no burnt ones...
Old Apr 21, 2010 | 01:33 AM
prinny's Avatar
Check your BCM. Located like above or right there the second fuse box is. Not the one next to the battery. The one on the driver's side next to the emergency break.
Old May 20, 2010 | 12:36 AM
Gorg3ou5's Avatar
thanks...so where is it? by the emergency breal? need to take out which panel?
Old May 20, 2010 | 12:47 AM
prinny's Avatar
There's a panel to the left side of the emergency break. Just take that out. The emergency break is the thing you push down and push up everytime you drive lol... And the panel is right next to it.
Old May 24, 2010 | 12:49 PM
angel_eclipse98's Avatar
try unpluging ur negative battery cable, I had the same problem a couple weeks ago and all you need to do is disconnect the negative cable and hook it back up
Old May 24, 2010 | 01:31 PM
prinny's Avatar
Yeah try that first because it'll reset all your electrical related stuff^ if that doesn't work and you don't know how to do any work with your BCM then you're basically SOL and you'll have to go to a dealership to have them reset it for you.
Old Jul 8, 2010 | 05:23 PM
Gorg3ou5's Avatar
thanks guys! the unpluggin works!
mike730
Jan 12, 2018 04:25 PM
mjfenix
Aug 17, 2017 05:49 AM
newg37
Jul 26, 2015 09:32 AM
attarday
Jul 15, 2015 04:03 PM
Jadenkid22
Jul 14, 2015 12:33 AM
