LED & headlight experts gather! Opinions and help needed fast!
Old May 5, 2010 | 01:05 AM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
For those LEDs, it's very simple. Just tap into any 12V source, like the city lights. Red wire tap into the +, black wire tap into the -. If you can solder, you can make everything cleaner with more solid connections.
Old May 5, 2010 | 01:18 AM
TIAN's Avatar
Hold The Line
Any of them blow out on you yet?
Old May 5, 2010 | 01:57 AM
biggz786786's Avatar
is this true for canadian spec too? whats the best place to tap into?
thanks
Old May 5, 2010 | 02:50 PM
E_K's Avatar
E_K
I haven't had any of my LEDs go bad, and this is after two years, starting with LEDs that I put in the front corner lights. I solder all my connections and use heatshrink over them.
Not sure about Canadian spec. But if you're not sure, you could always tap into the low beam.
Old May 5, 2010 | 03:15 PM
^what did you tap into to get em to work?
Jusseth
Sep 13, 2020 12:25 PM
nickmcc123
Lights
Oct 7, 2017 12:18 AM
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
