quad projector mod and sidemarker mod(fix)
sup guys jus wanted to post my version of the quad projector mod, i used a tsx lens for the top projectors and i believe lens from an sti or bmw for the lower projector, the third projector is a 3" projector from ebay. it didnt really matter to me about the quality for the 3" since it was going on my blinker housing.
i posted a few pics and as you can see i relocated my city lights into my blinker housing so i get the effect of three projectors. i wired up led halo rings to take place of the normal wedge leds for the city light.
the ring it emits on the garage was not something i was expecting but turned out to be pretty neat. its hard to explain but in person if you look at the headlights head on it looks like a ring of light in the blinker housing but as soon as you walk to the side it jus blinds you. every angle gives a different effect.
as for the sidemarkers i had them done by a company that i rather keep there name disclosed. in the process of removing my bumper to take my headlights off to begin my project i had removed the sidemarker and they basically fell apart....the black glue that was used to hold them together was jus melted and falling apart....i was very upset and felt ripped off but decided to take matters into my own hands.
i ordered a set of jdm bump style sidemarkers and cut them apart and transfered the leds over, sprayed them black and resealed them myself. i was very pleased with the results
i'll be updating more when i finish my project, lmk wat you guys think
Jus so I can clear things up the rings project from my blinker housing only when I'm right up against the wall as pictured in my first post.........other than that my beam is a straight cut. Ring pattern can only be seen wen an object like a wall is in front of it.
Jus a lens and I added a smd led ring inside and wired it to my city light
