Canadian coupes upgrading to projector headlights will lose DRL?
Old Nov 25, 2011 | 01:03 AM
parag_tdot's Avatar
Actually, just pull the drl plug out .. That's what I did.. I lost my day lights... But everything works just fine. I'll post a picture.
Old Nov 25, 2011 | 01:18 AM
davidxu's Avatar
put your lights to auto, put some electrical tape over the sensor so the car thinks its dark 24/7. This is how I run my projectors as my DRL. And now I never have to change settings for the light
Old Nov 25, 2011 | 02:04 PM
redpearl99's Avatar
then can i just remove this DRL module? I sure could use the space for my catch can
https://g35driver.com/forums/engine-...ml#post6168665
Old Apr 18, 2012 | 09:42 PM
TheG35Dude's Avatar
Sorry about not getting back sooner, the links have been fixed.
http://www.members.shaw.ca/wincana/G35CoupeLights.html
Old Nov 27, 2012 | 12:09 AM
Mr.g35_514's Avatar
How can I run just halos and no other lights on my 03 g35 coupe
Old Mar 2, 2015 | 06:24 PM
izzueeek's Avatar
Please Help
Recently i bought the passenger side 06 projector(canadian) in canada, but couldnt find the driver side. So i had to buy the driver side in the states.
So i got a shop to help me install it today and i got them to follow this guide: http://www.members.shaw.ca/wincana/G35CoupeLights.html
The problem was, there is a loud buzz from the drl module box and that the passenger side lights up dimmer than the driver side. And on the driver side blinker it lights up but dim.
As you can see driverside is brighter. He said that he follow all the instructions and that it might be the drl module box.
Also, back then when i had my reflectors, one side was off and it was to do with the drl module. So i got it resoldered and it worked.
What do you guys think? Any of you guys had this problem?
Oh and i dont have the hyperblinking problem.
Old Mar 2, 2015 | 06:30 PM
parag_tdot's Avatar
Remove the drl module
Just take of the drl little box on the passenger side under the hood... You will lose daytime but I've been driving like that for 5 years lol
Old Oct 14, 2016 | 10:16 PM
TheG35Dude's Avatar
Sorry guys , took that page down a while ago. Just came back to post the last remaining parts from my G35 coupe and found a lot of mail in my mailbox about the headlights.
I can't find the drawing explaining how to rewire the headlights to make them work properly but it is a simple rewiring of the grounds. You will loose the DRL but who really cares.
If you got the old 2003 lights just map out the wires from the headlight connector and compare them to the wiring of the 2006 and latter headlight wiring. They are almost the same except for the grounding wires.
I also remember adding a new connector (dual filament bulb) where the signal bulb was so the parking light was also on the amber signal light bulb. Made the 2006 projector look similar to the 2003 headlamps but better.
Old Apr 6, 2017 | 12:45 PM
ericlee303's Avatar
I printed off the diagrams, I can scan them again if anyone wants. I searched for a while and couldn't find them, and nobody else had a diagram that I thought was applicable.
Jusseth
Sep 13, 2020 12:25 PM
nickmcc123
Lights
Oct 7, 2017 12:18 AM
nickmcc123
Jul 29, 2015 05:14 PM
