Dome light issues
Old Oct 6, 2010 | 10:54 PM
Nomad397's Avatar
Originally Posted by EDW1NK
I just got a new dome light assembly on eBay for $35 shipped. Average is around $80. Just search for "g35 overhead". There's a listing starting at $14 right now. It'll solve all your proems.
so ur saying the dome / door switch on the ceiling is what blew out ?
Old Oct 6, 2010 | 10:58 PM
EDW1NK's Avatar
Yup. I had it replaced, and now it's as good as new. It's the clicker/switch that's actually fried.
Old Oct 6, 2010 | 11:02 PM
Nomad397's Avatar
thats wierd... i wonder how much the actual door/off switch is from infiniti...
Old Oct 6, 2010 | 11:04 PM
EDW1NK's Avatar
I was quoted around 100 for the switches itself.
Old Oct 18, 2010 | 12:36 AM
marcellsr's Avatar
I just ordered some of these LED interior lights. When i get them i'll no dout be changing them with the door open so electricity will be at the bulb. From what i just read here I probably should disconnect the negative side of the battery before I replace the bulbs ?
Old Oct 18, 2010 | 05:00 PM
the04coupe's Avatar
Sound like you fried the bcm . The door circuit in the bcm is very sensitive to shorts . Most likely it is a fried resistor or cap internally .
Old Oct 19, 2010 | 04:22 PM
Hi-TechG35's Avatar
It most definately is the BCM. I did this twice. First time I thought it was something I did after changing my dome lights to LED style type bulbs. I put them back stock and changed them again. Luckily for me the service tech where I get service when needed hooked me up. The BCM will have to be replaced and keys will need to be reprogramed.
Old Oct 20, 2010 | 10:59 PM
Nomad397's Avatar
the door lights still work when the doors are opened. i pulled the dome switch and un plugged the bcm and could not get continuity between the wires from the bcm to the dome light switch...
Old Oct 20, 2010 | 11:49 PM
the04coupe's Avatar
If you fried the wire to where your not getting continuity through is than you almost 100% fried the bcm . Just tapping the positive and negative as fast as possible is enough to fry the bcm . If it does turn out to be fried before you go pay 1000+ and have to have your ignition changed or reprogrammed etc ,i can try to fix it for you . I have fixed them b4 on other cars .
Old Oct 21, 2010 | 09:28 PM
Nomad397's Avatar
pm'd
Old Mar 24, 2011 | 10:31 PM
Mcloukes's Avatar
i'm having the same issue with my dome/maps lights as well. I recently bought some LED's to replace the stock amber interior lights. When i first installed them it kept blowing the fuse so I replaced the fuse, brought them back and grabbed other LED's. These didn't blow the fuse but are frustrating to turn on as i have to hold the switch a couple of times just to get one of them to stay on while the other map light is trying to work but only flickers.
i know the fuse is good and i know i installed them the right way so i'm left thinking that the first LED's must of screwed something up because before i installed anything the stock lights worked fine. i'm hoping it's not the BCM as there's still power going to the lights, but maybe it needs to be reset (if so, is it as simple as disconnecting the battery, positive and negative terminal?).
Any ideas would help? Also i haven't replaced the door lights yet and the original stocks lights in there are still working fine
Old Mar 25, 2011 | 01:25 AM
LEDmarkers's Avatar
The bcm in your case is fine . It sounds like the first LEDs had a short .Maybe that fried a switch or wire which is why your having problems now . If its working at all now your lucky the bcm didnt fry .
Old Mar 25, 2011 | 09:40 AM
Mcloukes's Avatar
that's good to hear that my bcm is probably still okay. but if I fried a switch or possibly a wire. What's the best way for me to go about fixing them, is it simple to DIY?
Old Jan 24, 2012 | 04:18 PM
krzitfro's Avatar
Does anyone know whats wrong if my dome light and the sunroof is both not working and everything else works fine????
Old Jan 24, 2012 | 09:46 PM
  #30
TunerMax's Avatar
G35
^Well, did you check the fuses?Well, did you check the fuses?Well, did you check the fuses?Well, did you check the fuses?Well, did you check the fuses?Well, did you check the fuses?Well, did you check the fuses?Well, did you check the fuses?Well, did you check the fuses?Well, did you check the fuses?
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
