Dome light issues
Old Jul 2, 2010 | 11:39 PM
OtisG35's Avatar
Dome light issues
So today I was replacing my stock dome light bulbs to LEDs. I put one of the LEDs on backwards and heard a static sound. My dome or map light didn't work anymore. So i disconnected the battery and reconnected. The lights are now back on. However the open door function on the doom light doesn't work. The light does not turn on, however if i press the map light the lights work. I have it switched to door function also. I'm out of ideas and its frustrating. Does anybody have any ideas?
Thanks
Old Jul 3, 2010 | 12:25 AM
prinny's Avatar
Was anything metal touching the LED when you heard that static sound? Or what were you doing? Because you might of messed up the BCM and the only way to have it checked and reset would be to bring it to a dealership. The dealership is like the only place where they have that tool that they can use to do that with.
Or also make sure you check the fuse boxes to see if you blew any.
Old Jul 3, 2010 | 02:10 PM
OtisG35's Avatar
I put the led bulb in the wrong way I guess and thats when the sound occured. I checked all the fuses and they are fine. This doesn't sound to good. It sucks because everything works just fine except for the dome light. map lights works also.
Old Jul 3, 2010 | 02:25 PM
Trigo's Avatar
Your in luck same thing happend to me yesterday took me forever to figure it out...
Ok go to your Fuse Box on the left side of your car open the panel and look at the fuse box map and go to Electrical Parts Section under " IGN " swap the fuses with the Spare - Make sure your battery disconnected
Old Jul 3, 2010 | 04:18 PM
OtisG35's Avatar
Sad times...that didn't work either. Was your fuse burned out? Could you see it from lookin at it?
Old Jul 3, 2010 | 08:25 PM
prinny's Avatar
You should be able to tell if your fuse is burned out or not. If you can't tell then you can always test it with this one tool that you can get from any auto shop.
You'll probably have to end up going to the dealership to get that sorted out because it most likely is a BCM problem. Expect to pay like $50+ though ..
Old Jul 6, 2010 | 12:47 PM
OtisG35's Avatar
damn it...all that over changing my damn dome light. Should have just kept it stock!
Old Jul 6, 2010 | 02:53 PM
prinny's Avatar
You just had bad luck lol. Barely anyone runs into a problem like that. Stock bulbs suck donkey ***** anywayss.
Old Jul 27, 2010 | 02:25 AM
Night's Avatar
no i have the same problem with my car. anyword on how much the dealer costed or if u fixed it urself???
Old Jul 27, 2010 | 12:03 PM
EDW1NK's Avatar
same problem here, all my interior lights are working except for the dome lights. changed all the fuses and still nothing!
Old Aug 17, 2010 | 03:56 PM
OtisG35's Avatar
I gave up on this guys. No luck for me at all. If you find anything let me know as well.
Old Aug 17, 2010 | 06:53 PM
EDW1NK's Avatar
the cheapest ive found is on ebay, which is $80 for the entire unit. try looking around on car-part.com
Old Aug 31, 2010 | 01:03 PM
JAYRIPPA420's Avatar
this happend to me too its not rare....i got in an accident and had it at a shop for a week when i got the car back everthing worked but ...that static sound effected my cig lighter light . the doors and the dome and vanity mirrors. **** sucked ...now they work fine. im getting leds in the mail today...lol i will be disconnecting my battery before i do ne electrical work no matter how easy it is.
Old Oct 6, 2010 | 09:47 PM
Nomad397's Avatar
still no fix for this issue... same thing just happened to me. now everything works but the dome lights dont come on when the door is opened... i read something about a bcm fuse. anyone have an idea ?
Old Oct 6, 2010 | 10:07 PM
EDW1NK's Avatar
I just got a new dome light assembly on eBay for $35 shipped. Average is around $80. Just search for "g35 overhead". There's a listing starting at $14 right now. It'll solve all your proems.
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
