Rear Driving lights and tag light out, help!!!
I was wondering if anyone had this problem before, recently my 3rd brake light when out, and now at night, the running brake lights are out as well? The brake lights work when brake petal is pressed and blinkers works but no running lights on the brakes. I checked all the fuses and they are fine, there is no power going running brake light wires. I'm thinking maybe a relay but I have no manual, could anybody help???
Haven't been driving at night to avoid major ticket for tag, 3rd and running lights out.
i had a similar problem and found a third fuse box just behind the battery to access it u have to remove the battery cover and the remove the passenger side cowl that's connected to the windshield the u will see the box that houses a 10amp fuse for the brake lights etc.it fixed my problem of no running light also no lights on center console interior.once changed everything worked
Micale757
Lighting
Apr 8, 2020 10:46 AM
Wayne9011
Jul 27, 2015 11:25 AM
