Help!! Map Lights Malfunctioning
Old Jul 28, 2010 | 04:33 PM
seizures's Avatar
Hey everyone, I had just put LED's into my map lights and (after proceeding to blow the fuse multiple times) I can only get one side to work. I've tried rotating them and switching them out, even going back to the stock bulbs and only one side will turn on.
I wonder if I fried a circuit board or something? It can't be a fuse because all of my other interior lights turn on.
When I click the side that doesn't work on the diode dimly flashes for a second, but no luck trying to get it to stay on.
I hope it isn't a BCM problem. If it is, do you think the unit will need to be replaced?
Any suggestions? Thanks!
Old Aug 7, 2010 | 04:26 AM
EDW1NK's Avatar
same thing happened to me. after some testing, i found out it was the switch for the map lights.
Old Aug 7, 2010 | 11:39 AM
seizures's Avatar
Yep I figured out the same thing. Have any idea where we could order just the switches? Miyama is the manufacturer, part is MS-010A.
Old Aug 15, 2010 | 11:32 PM
brmintz's Avatar
ahh same exact thing just happened to me! im down for a solution
Old Aug 15, 2010 | 11:34 PM
seizures's Avatar
I haven't had a bit of luck. I think I'm going to have to resort to buying a new unit off of ebay ~40$
Old Aug 22, 2010 | 11:54 AM
OtisG35's Avatar
did the new housing fix the issue?
Old Aug 23, 2010 | 02:57 PM
EDW1NK's Avatar
i swapped out the map light switch/assembly and everything works fine. try looking on car-part.com. im sure most of the junk yards are willing to ship
Old Aug 23, 2010 | 03:28 PM
brmintz's Avatar
found a unit on that parts site thanks for the link! It came out of a sedan and I have a coupe... are they the same?
-thanks again for the help
Old Aug 23, 2010 | 03:58 PM
brmintz's Avatar
just checked both FSM's and apparently they are for 1st gen (AFAIK), for anyone else looking to replace theirs
Old Aug 23, 2010 | 04:42 PM
ryanwiggum's Avatar
I have the same problem in my coupe
Old Aug 23, 2010 | 06:08 PM
seizures's Avatar
What part did you search for on car-part?
I've tried going through the list but haven't been able to find anything that has to do with interior lighting.
nightowl.czc
SouthEast
Aug 28, 2015 08:36 PM
brane123
Interior
Aug 23, 2015 06:55 AM
EliteG
Engine - Electrical
Aug 5, 2015 07:50 PM
