Radio buttons not lighting up
Old Aug 3, 2010 | 12:16 PM
Chult86's Avatar
Dash works, AC/Temp window works. Even the red lights under the AC buttons work, but the radio buttons aren't illuminating.
Also, when I turn on the headlights, nothing dims at all, and the little switch down and to the left that's supposed to affect the brightness does nothing.
Help please
Old Aug 3, 2010 | 11:51 PM
alexcaro's Avatar
have you checked your fuse?
Old Aug 3, 2010 | 11:52 PM
Chult86's Avatar
I was toldthat there is no fuse specific to this problem :/
Old Aug 4, 2010 | 01:26 AM
alexcaro's Avatar
You may want to look into that again, there is a 15amp fuse by your battery that may need to be replaced. Do your DRL turn on and or your brake lights when your headlights are on? If not you definitely have a blown fuse.
Old Aug 4, 2010 | 02:23 PM
Chult86's Avatar
I checked that fuse and it looks to be fine
mike730
Jan 12, 2018 04:25 PM
G35forlife21
Aug 26, 2015 07:34 PM
ev_g35
Interior
Aug 14, 2015 02:05 PM
Frostbite91
Aug 12, 2015 05:16 PM
Cacoepy
Aug 3, 2015 01:09 PM
