Bad BCM map light problem need technical help
Old Oct 13, 2010 | 12:51 PM
Nomad397's Avatar
Unhappy Bad BCM map light problem need technical help
Ok so when installing LED's in my Map light (early 03 sedan) i heard a buzzing sound and quickly removed the LED and flipped it around. now the LED's work but not when the door is open (with the door switch in the door position). I bought a map light assembly on ebay and replaced it only to find out i still have the same problem. What i need is for someone to give me the wire colors to splice to get the map lights working when the doors are opened. i'm almost sure there is 12v + constant at the moon roof switch so all i need is the negative trigger for the door to be spliced into the negative of the map light switch. if anyone has the wiring diagram and some know how please post up a solution ! id rather not pay to replace the bcm if i can just splice a couple wires to make this happen.
mike730
Jan 12, 2018 04:25 PM
wonderizm
Sep 24, 2015 03:09 AM
EliteG
Engine - Electrical
Aug 5, 2015 07:50 PM
newg37
Jul 26, 2015 09:32 AM
attarday
Jul 15, 2015 04:03 PM
