2003 Headlight Help!!
Old Nov 5, 2010 | 09:14 AM
ERILUDE's Avatar
I have an 03 coupe. After drawing one too many lines from the factory foglight ballast to convert to aftermarket HID. I blew the circuit. I was just working too fast and broke all my rules. Nonetheless, can anyone guide me to the proper locations from the headlight/fog light relays and fuses. I've looked at the driver kick and engine compartment to no avail.
Help Please!!
Old Nov 5, 2010 | 09:27 AM
herrschaft's Avatar
There's a third fuse box behind the battery
Old Nov 5, 2010 | 09:30 AM
ERILUDE's Avatar
Ok, is it accessible without removing the battery?
Old Nov 5, 2010 | 09:40 AM
herrschaft's Avatar
Maybe, your better off just removing it.
Old Nov 5, 2010 | 09:43 AM
ERILUDE's Avatar
Fair enough, I knew there had to of been another fusebox.
Old Nov 14, 2010 | 08:27 AM
Titan23's Avatar
Let me know how it turns out. I have a similar issue. My passenger side low beam is out and it wont come back on. I have an 03 coupe with the 06 headlights. I had H.I.D.'s as well but Im using the factory ballast. At first it would go out and if I tapped the headlight housing it would come back on. Now its completely out. The bulbs are relatively new so I'm hoping that its just a short or blown fuze or something of that nature
Old Apr 14, 2011 | 10:27 PM
ERILUDE's Avatar
There is a panal behind the battery cover in the top left corner that borders the windshield. If you remove that, the fuse box is against the fire wall. My foglight fuse was blown.
Problem now is only my driver lights come on, the passenger doesn't work at all.
nissandrifter32
Dec 22, 2015 04:28 PM
alessandro
Oct 8, 2015 09:29 AM
Joe Gargano
Sep 18, 2015 11:17 AM
ENTRAPM3NT
Sep 16, 2015 01:21 AM
