loose side marker
Old Dec 29, 2010 | 10:58 PM
saywat?'s Avatar
loose side marker
is there a fix for the loose side marker syndrome? the back end of the light is a bit loose and has some play vs the front end is nice and tight. or is this how it is from the factory? is it jus a matter of bending the metal clip and making it wider? i tried bending it alittle and seems like theres no difference not sure if i just never bend it enough. didnt wanna end up breaking it. thanks
Old Dec 29, 2010 | 11:45 PM
Project's Avatar
double sided tape!
Old Dec 29, 2010 | 11:51 PM
BW350GTskyline's Avatar
yea i had this problem before... u have to bed the metal tabs outward they wont break.. and yes double sided tape does work..
Old Dec 30, 2010 | 12:33 AM
gary c's Avatar
You'll need to bend the spring and it will snap back into position or if you're lazy try a very small amount of Super Glue, at least they won't be easy to steal....
Gary
Old Dec 30, 2010 | 12:54 AM
saywat?'s Avatar
i bought some cabinent glides, i thnk that's wat it was called from the hardware store. ill see if that tightens up the gap so the clip will latch on tighter.
flytim3
Jul 29, 2016 10:17 PM
G35forlife21
Aug 26, 2015 07:34 PM
realtalk21
Jul 20, 2015 09:07 AM
wylin
Lights
Jul 18, 2015 06:12 PM
